frooze???
  • Thread starter Thread starter l3urnin0ut88
  • Start date Start date May 2, 2009
l3urnin0ut88
9
  • May 2, 2009
i just finished a auto to 5-speed conversion on my 88 gt today,when i started it up it ran for a minute and stalled,like it normally would on any first start,but when i went to restart it,it just went clunk ,i tried to turn the motor over manually by the balancer bolt i cant budge it any way at all,,any clues what could have caused this??it really has me quite stressed
asecretfile
228
  • May 2, 2009
was it out of gear? Ive caught myself trying to turn it while it was in gear, forgetting to throw it in neutral
l3urnin0ut88
9
  • May 2, 2009
yes,i even went as far as pulling out all the plugs,and trying to turn it over from the balancer bolt with a socket and ratchet,,,i cant budge it at all
BYRDPE
1,556
Memphis,Tn.
May 2, 2009
  • May 2, 2009
Check the starter. It may be binding.
sickazzstang
55
  • May 2, 2009
Yup sounds like the wrong flywheel to me or binded starter...
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
May 2, 2009
  • May 2, 2009
My guess is something in the bellhousing is hitting.
Take the starter out. See if the edge is damaged.
I'm doing my AOD to 5-spd swap and noticed this
http://forums.stangnet.com/784095-aod-t5-starter-hits-pressure-plate.html
BYRDPE
1,556
Memphis,Tn.
May 3, 2009
  • May 3, 2009
I actually had an issue with the KC clutch hitting the bellhousing when I first did my swap. Had to gring down a few spots for it to clear.
ShortThrow50
923
Pa
May 3, 2009
  • May 3, 2009
The guy didn't mention any abnormal noise when he had it running for a few seconds. If there was an issue with something hitting something, he would have heard it clunking like crazy the first time.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
May 3, 2009
  • May 3, 2009
True, which makes me thing something may have come loose.
I'd pull the cluthc fork cover and take a look inside.
Turd Tops
103
South Lyon , Michigan
May 3, 2009
#10
  • May 3, 2009
  • #10
This may sound stupid but did you tighten the cable to the starter? I've done it. Just finger tighten them and forgot about it. It would start once then it would'nt start the next time. After i remembered what i did i tightened it and it was all good again
stykthyn
5,232
2,652
223
gainesville
May 4, 2009
#11
  • May 4, 2009
  • #11
yeah, but taht wouldnt cause it to bind to the point he couldnt turn the crank by hand...
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
