  • 1994 - 1995 Specific Tech
fuel filter lines?
  • Thread starter Thread starter govtmule
  • Start date Start date Jul 29, 2004
G
govtmule
95
  • Jul 29, 2004
I was driving on the interstate the other day, and i got off on a ramp and hit the gas and the car sputtered and no rpms felt like it was out of gas so i pull over and sure enough im leaking gas from under the tank. I slide under for a look andthe line going into the fuel filter had poped off. I put it back on and continued driving, sure enough it happened again. I put it on one more time and it has not happened again yet. Anyone knoe what caused this???
deadly97snake
592
Manchester, NH
Jul 29, 2004
  • Jul 29, 2004
I just did my Fuel filter about three days ago. There were two plastic clips that came with the new filter. They went inside the fuel lines right at the end of lines right where they connect to the filter. Mabey your clips are missing/broken?
94TURBO5 O
2,509
VA
Jul 29, 2004
  • Jul 29, 2004
There should be a clip on it or something to hold it onto the nipple.
RIO5.0
6,892
N.H.
Jul 29, 2004
  • Jul 29, 2004
Sounds like the clip took a dump??? Go to any parts store and they usually have em in those "HELP" racks, little odds and end stuff...
Thats crazy chit....fuel dumping out...EEK...Never heard that one before..
M
mackey
1,284
Beverly, Massachusetts
Jul 29, 2004
  • Jul 29, 2004
How do you take the fuel lines off the filter...?
RIO5.0
6,892
N.H.
Jul 29, 2004
  • Jul 29, 2004
See that White clip...Remove that....pull the line off...The clip has little barbs that grip and it locates around the diameter of the filter...A new filter will have 2 new clips with it....Make sure you check the box for em...Got boned like that before... You can re-use the old ones though...unless you bungered them up coming out....
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
