  • SN95 4.6L Mustang Tech
Fuel Filter
  • Thread starter Thread starter JRS02GT
  • Start date Start date Nov 1, 2006
JRS02GT
39
Ruskin, Fl.
Nov 1, 2006
  • Nov 1, 2006
I am going to change my fuel filter this weekend, but I have a question. I read in the shop manual that you need to relieve the pressure in the fuel system before removing the filter. I know where the shrader valve is, but have never touched one. How does that work?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 1, 2006
  • Nov 1, 2006
The valve is located on the fuel rail, passenger's side front. It is just like a bicycle or car tire valve. There is a small stem in the center that opens when pressed in.
merc123
420
North GA
Nov 1, 2006
  • Nov 1, 2006
I used a small flathead screwdriver and stuck it down in the valve to relieve the pressure. Anything will work that will fit and push the valve. Also make sure you have a towel or something to catch any fuel that may run out. Watch the eyes too.
sgarlic
3,085
Nov 1, 2006
  • Nov 1, 2006
I just let mine sit overnight. It didn't spray me at all.
DTMach1
240
Virginia Beach, VA
Nov 1, 2006
  • Nov 1, 2006
I just pulled the cap off and let it sit for a while before I touched it.
You still get some spillage though.
Also remember you'll need the disconnect tool. Its the metal red one at Autozone etal
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Nov 1, 2006
  • Nov 1, 2006
Werd. I just usually let my car sit for a bit and then change it out. Haven't had any issues so far.
streethorse
1,042
Dallas Texas
Nov 1, 2006
  • Nov 1, 2006
just wrap a t- shirt size rag around the release point on the fuel filter.....
toward the gas tank side....... not that much gas will come out any way...
I've done it that way 3 times, no problem.
propellerhead
1,541
"but what's with the but shots?"
Nov 1, 2006
  • Nov 1, 2006
I've had maybe a cup of fuel come out. All I did was remove the fuel filler cap. Just hold a rag to the connection right when you're about to pull them apart.
Mustang5L5
Mod Dude
Feb 18, 2001
43,324
18,049
224
Massachusetts
Nov 1, 2006
  • Nov 1, 2006
Unplug the inertia relay in the trunk and run the engine til it runs out of fuel.
Not as messy
Saleen4971
664
Setauket, LI
Nov 1, 2006
#10
  • Nov 1, 2006
  • #10
if your car was on beforehand, i woudl just flip the inertia switch like mustang5l5 said, and let it run till it dies.
should i go with a ford OEM filter, or can i get one from our usual parts store?
Mustang5L5
Mod Dude
Feb 18, 2001
43,324
18,049
224
Massachusetts
Nov 1, 2006
#11
  • Nov 1, 2006
  • #11
Ford OEM
BlackenedSVT
1,841
New Jersey
Nov 1, 2006
#12
  • Nov 1, 2006
  • #12
could always clamp off the lines with vice grips
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Nov 1, 2006
#13
  • Nov 1, 2006
  • #13
Well the usual parts store should have Motorcraft, so pick one of those up
Saleen4971
664
Setauket, LI
Nov 1, 2006
#14
  • Nov 1, 2006
  • #14
nah, they would probly only have like, a fram fuel filter or something like that.
E
El Diablo
53
#15
  • Nov 1, 2006
  • #15
Fuel filter how too:http://www.bullittarchive.com/WebHelp/BullittArchive.htm
JRS02GT
39
Ruskin, Fl.
Nov 1, 2006
#16
  • Nov 1, 2006
  • #16
Thanks for all of the replies. I have the tool to take it off and am going to use a small clamp I have to keep the fuel spill to a minimum. Sounds like it should be a piece of cake. Thanks again guys!
P
Pennywise2
Banned
May 16, 2006
1,379
#17
  • Nov 2, 2006
  • #17
Change it with a Motorcraft fuel filter everytime.
Henceforward
The Avatar Master
485
#18
  • Nov 2, 2006
  • #18
Saleen4971 said:
Fram fuel filter
Stay far away from anything FRAM... low quality crap.
WIX or Motorcraft fuel filter only.
Neat info on why Fram sucks too:
http://minimopar.knizefamily.net/oilfilterstudy.html
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html
StangPro
441
Roseville, MI
Nov 2, 2006
#19
  • Nov 2, 2006
  • #19
You need to explain why Fram sucks????
I'd avoid running the car till it dies, it's hard on the engine. Remember, lean is BAD...
Just push the valve (if you have one) and do as the link above says.
When buying the tools, make sure the edge (top) of the tool where it fits into the line is squared of or really close to it. Many tools (cheap ones) are tapered and they usually don't work on Stang lines.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
