Fuel Pressure Drop with Engine Rev
  • Thread starter Thread starter AnthonyR23
  • Start date Start date Jul 7, 2009
AnthonyR23
661
Ontario
Jul 7, 2009
  • Jul 7, 2009
Hi can someone tell me what would be approx. normal fuel pressure psi points roughly.
Like let's say you have 39 psi no vacuum. Then wish vacuum hooked up it should drop, to about what??? So when I rev the engine up to let's say 2500rpm what should my fuel pressure change to? Cause mine drop's to about 25 psi.
Have been getting code 96 engine off, but can start the car up fine, drive around the block, seems more sluggish than it should be especially at low rpm, can get it going at about 2500 with a slight bit of poping/firing in the exhaust, kinda feels like it bogs a bit, get's kinda like jumpy, not sure the right word, but say when accelerating kinda does the thing where its trying but isn't really smooth kinda struggles but does seem to manage when up there a bit. Was getting to lean then to rich codes, especially when I played with the regulator. Codes I have seen are engine off 96, first engine on 41 and 91, switched both o2's and got just 41. Have 4 o2's in total so can switch through them to find 2 good ones. Anyways after swapping through a bunch of o2's and still getting 91, thought I would up the fuel pressure a bit. Got code 92. But with very slight psi adjustments like 2psi here or there.
So tommorrow I am going to swap my stock fuel pump out for a 190 lph fuel pump, swap the fuel filter. Then will jumper the fuel test circuit key on engine off to get 39 psi with no vacuum. Then I will check with the engine running vacuum off that I am maintaining 39 psi. Will shut it off and reconnect vacuum. Dump engine running codes, take it for a spin, then check error codes. Then if I get 41 or 91, I will swap whatever code side 41right 91left o2 sensor out, dump codes again and take it for another spin. If I come back and still have error codes I am completely lost. Other last thing I will try, and if I am getting engine lean or rich, after all the above is to re-adjust the fuel pressure regulator by approx. 2psi in the opposite direction of the error code from my starting point. Eg. if I get 92, to rich I will lean it out by dropping my fuel pressure to 37psi., and if I get another to lean, I will bump my fuel pressure up to 41 psi. Other than this I am absolutely lost in every way!
If you think I am on the right path with swapping out the fuel pump and fuel filter than I hope your right! But if after all of the above, if there is anything you guys can do to help me that would be great! Because if this doesn't work I really don't know what else I can try! Thanks guys!!!!!
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 7, 2009
  • Jul 7, 2009
Sounds like the same problem I had when I had a bad fuel pump. Doesn't mean thats what it is for sure, but thats the exact same syptoms I had. My fuel pressure would drop down to around 20-25 psi when it got to the higher rpms. If I were you I would try swapping out the fuel filter first before tackling the pump. Cheaper and a lot easier to do.
AnthonyR23
661
Ontario
Jul 7, 2009
  • Jul 7, 2009
I know it does seem like a pain to have to drop the gas tank, but I do have this 190lph intank fuel pump that I bought thinking I may need it. But I agree it would be nice to just be able to change the fuel filter which I haven't ever changed. But thinking I am gonna bight the bullet tomorrow while on holidays and just get it done!
mustangsquared
828
new bern nc
Jul 7, 2009
  • Jul 7, 2009
So what is normal?? Dropping 3-5psi or should there be no drop at all?? I am curious as well cause I know mines drops when I rev her and I have a 190lph fuel pump. If its not suppose to drop at all then that might be my surge issue/hanging idle.
ShortThrow50
923
Pa
Jul 7, 2009
  • Jul 7, 2009
Your running a stock pump on a 347? Thats crazy. What size injectors are you running? I run a 255 pump (same price as a 190) and 42 pound injectors on a mild 10:4:1 compression 347 and at 39 psi. No custom tune either and my car runs perfect. Unless im missing something, the reason for all your headaches is your fuel system isnt up to par
ShortThrow50
923
Pa
Jul 7, 2009
  • Jul 7, 2009
no, its supposed to drop. your car is perfectly fine
Dino Dino Bambino
1,672
89
79
Cyprus
Jul 7, 2009
  • Jul 7, 2009
x1,000,001
Upgrade the fuel pump.
mustangsquared
828
new bern nc
Jul 7, 2009
  • Jul 7, 2009
Thanks...I was worried I would be replacing the fuel pump this weekend...
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Jul 7, 2009
  • Jul 7, 2009
um... I thought if anything fuel pressure was supposed to go up when you rev it. Mine goes up to around the 39psi I have it set at at idle without vac
AnthonyR23
661
Ontario
Jul 7, 2009
#10
  • Jul 7, 2009
  • #10
I does make sense to me that you would loose some psi as the pressure is probably relieved because the engine is using the fuel that's in the rail, so I assume why a slight drop is normal. But like a 15psi drop probably isn't normal. So thinking the fuel pump just needs to be able to keep up.
So here's an update:
I have the gas tank out, which wasn't too bad at all, the filter looks pretty rusty, wouldn't surprise me if it was the original one. So I got it out, used a scrapper to get away as must loose rust under there and gave it a good paint while I was at it. So got the tank off and capped everything off, gave it a power wash. There is a hole in the top of the tank, really rusty.
So luckily I have two spare tanks in the shed, one from a 83 gt vert, and the other from a 6 banger vert also 83 that we used to have. Only problem is it doesn't have the fuel gauge sender unit for the fuel gauge. But the tank is mint. So I think for now I am going to get it up there and just put fuel in often. Will kinda suck for a long trip.
Not sure what else to do. Any suggestions?
AnthonyR23
661
Ontario
Jul 7, 2009
#11
  • Jul 7, 2009
  • #11
So once I actually got the units out, now understand why my gauge wasn't 100 percent! The float was there but broken and kinda dangling.
So with my 88 tank on the upper part there is the fuel pump and lower down in the middle is the fuel level sender.
On the 83 tank there is no hole in the middle where my 88 tank sender is. It uses the hole where the fuel pump goes on my 88 as the sender and must have some sort of mechanical or external fuel pump.
So what I did is gave the tank from the 83 that is in really great shape a good paint with a black rust paint, and am letting it dry over night, then I am gonna figure out a way to use the float if possible on the bracket that holds my new fuel pump. I'm sure this could work some how.
I would throw on some pics, but for some reason my account on here can't seem to handle pic attachments. Like my allowable storage is full. Guess I could delete some.
I will take a few later and try to get them on.
ShortThrow50
923
Pa
Jul 8, 2009
#12
  • Jul 8, 2009
  • #12
ok but still, if you put that stock pump back in there, your still not gonna have enough fuel. You need to install a 255lph walbro. they cost 120 bucks. I dont know what injector you run and i dont know the specs on your 347 but i would run at least a 36 pound injector to be on the safe side. more fuel is better than not enough.
AnthonyR23
661
Ontario
Jul 8, 2009
#13
  • Jul 8, 2009
  • #13
So it was a real pain in the a**! But I managed to get the current bracket modified so I can use the same hole for the old fuel level sensor. Cut my fingers up pretty good, but got it done! So its not a stock fuel pump its the 190lph unit which I think should be just fine for 30lb injectors running not at full duty.
So I have everything wired up and all lines hooked up including new fuel filter. Going out for dinner but when I get back am hoisting it back up and installing the vacuum line. Then I should be good to go.
So I will let you guys know tonight if I am still getting error codes.
Am going to cross my fingers!
ShortThrow50
923
Pa
Jul 8, 2009
#14
  • Jul 8, 2009
  • #14
yeah, let us know man. glad you made out ok
Rocky Rodriquez
51
#15
  • Jan 23, 2017
  • #15
Well?
General karthief
Mod Dude
Aug 25, 2016
28,059
10,683
213
polk county florida
Jan 23, 2017
#16
  • Jan 23, 2017
  • #16
Rocky Rodriquez said:
Well?
Hey rocky, thats an seven year old thread, plus bigger motor and bigger injectors, you likely need to replace your fuel pump and filter.
Reactions: Rocky Rodriquez
Rocky Rodriquez
51
#17
  • Jan 23, 2017
  • #17
I bet ur right buddy thanks again I'll keep y'all up dated
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Sunday at 2:23 PM
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sunday at 2:40 PM
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
C
  • Locked
Fuel pressure too high
  • Canadianfox
  • Jul 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2025
