Fuel Pressure & vacuum question
  • Thread starter Thread starter cobra11182
  • Start date Start date Mar 1, 2004
C
cobra11182
265
Baltimore, MD
Mar 1, 2004
  • Mar 1, 2004
I just installed an adjustable fuel pressure regulator, and noticed that when I set the pressure with the engine running and no vac line, it read 40. Then I hooked up the vaccum line, and it still read 40. The car runs ok, but then when I take it out, the pressure stays right at 40, no matter how hard I hit it. Does this mean that I have no vaccum? SHouldnt that vacuum line adjust the fuel pressure with the RPM's of the engine? Also, since the vaccum line comes straight out of the intake, wouldnt the leak have to be in the line itself? THanks for any input
E
eagle87
62
New York
Mar 1, 2004
  • Mar 1, 2004
When you took off your regular and replaced it, Now you might have air in the system. At any rate you should have vaccum on that line constant. Start the car blead some fuel from the scrader valve and go from their good Luck
ss93cobra
1,422
Wilmington NC
Mar 1, 2004
  • Mar 1, 2004
Make sure you haven't accidently forgotten to reinstall the vaccuum line at the intake, it's been done before by others and overlooked. If it is on, remove the tube and put a rubber hose on it or take your air line and blow through the factory plastic tubing/vac line to make sure it isn't restricted. Should be simple enough to fix a vac leak too. Good luck
C
cobra11182
265
Baltimore, MD
Mar 1, 2004
  • Mar 1, 2004
but the fuel pressure should definetly change with rpm's right? and it should definetly drop when the vacuum line is conected right?
I
Idwitheld-1`
335
Portland Oregon
Mar 1, 2004
  • Mar 1, 2004
If you have adequate vacuum on that line you should be able to get the line to suck and "stick" to your finger....plus you should be able to hear the sucking sound from that hose.
Increase in vacuum = decrease in FP
Decrease in vacuum = increase in FP
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
