Fuel Pressure
  • Thread starter Thread starter Turkey Sammich
  • Start date Start date May 21, 2007
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
May 21, 2007
  • May 21, 2007
What should the fuel pressure be at on a nearly stock 93 LX?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 21, 2007
  • May 21, 2007
For some reason, 39lbs or so with the vacuum line disconnected rings a bell.
Turkey Sammich
Jul 12, 2006
154
May 21, 2007
  • May 21, 2007
Any reason it would decide to go from 39 down to 33?
Flavadave4
1,044
21
49
Utica, NY
May 21, 2007
  • May 21, 2007
With the vac line off and the car at a warm idle it sould be around 39psi......do you have an adjustable regulator?
Turkey Sammich
Jul 12, 2006
154
May 21, 2007
  • May 21, 2007
I have a Paxton fuel pressure regulator with a Summit Fuel Pressure Gauge.
91 HATCH
Banned
May 17, 2007
262
illinois
May 21, 2007
  • May 21, 2007
I WOULD TURN IT UP.YOUR PUMP MIGHT BE GETTING WEAK AND GIVING THE LOW PSI
HISSIN50
34
129
May 22, 2007
  • May 22, 2007
Above is correct (I think). 38-39 PSIG at simulated WOT (vac line off and capped). Once the vac line is reinstalled, a stockish cam will have you at 32-33 PSIG, though anything over 30 PSIG is within spec as I recall.
Good luck.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
May 22, 2007
  • May 22, 2007
38-39 PSI with vacuum line off, along of blown stuff I tend to run 41-42 PSI
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
A
87 GT - Low Fuel Pressure Problem
  • Asbury
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
getting 90 PSI at fuel rail - help
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
