fuel problem
  • Thread starter Thread starter hulk_lil87gt
  • Start date Start date Jan 3, 2010
H
hulk_lil87gt
47
  • Jan 3, 2010
ok to start i am going nuts trying to find it. heres my problem if the car is cold it will start fine and idle fine that is until i step on the gas just a lil bit and the car brakes up and back fires. let it warm up and u can rev it up but if u put it i 1st and start to go the car brack up again and will do this for maybe 10 to 15 mins of driving and wen its hot it will run perfectly. ok now say i stop to get gas turn the car off go to start again just turns over over over if i hold the gas down all the way to the floor then try starting it starts right up. the car is an 87 gt speed density. has the flowing done cobra intake under drive pullies msd cap n rotor full exhaust system adjustable fuel reg.
what i think might be wrong with it. injectores leaking or bad, the flange on the top of the gas tank feel and messed up the fuel pump (have new one ready to go in) or the adjustable regulator is bad (also have a new to go in)
thanks
apollo12
155
port st.lucie fla
Jan 3, 2010
  • Jan 3, 2010
First off did you pull the codes?
H
hulk_lil87gt
47
  • Jan 4, 2010
no i havent pulled any yet waiting for my check to come in and also the weather hasnt been the nicest out here..as soon as i get them i will post them but n e one elas that may point in the right direction would be great. or what codes i should deffienetly be on the look out for thanks
H
Haus
408
  • Jan 4, 2010
Possible ECT issues
H
hulk_lil87gt
47
  • Jan 4, 2010
Haus said:
Possible ECT issues
Think I will have n e problems with an 88 speed density computer car is an 87 gt
Posted via Mobile Device
H
Haus
408
  • Jan 4, 2010
ECT = Engine coolant temp sensor
H
hulk_lil87gt
47
  • Jan 4, 2010
Lol sorry not so great with terms yet which coolant temp the one in the intake manifold or the heater core rails
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
  • brandyn200
  • Jun 20, 2026
AeroCoupe
