  • 1994 - 1995 Specific Tech
Fuel Problems...
  • Thread starter Thread starter SN95Oh
  • Start date Start date Mar 21, 2004
SN95Oh
91
Oklahoma
Mar 21, 2004
  • Mar 21, 2004
Car:
94 Mustang GT
3.55 Gears
Trickflow intake
Flowmaster exhaust w/ H-pipe
Okay I just recently installed a new intake on my car (trickflow).
And it ran strong for a while and 2 days later, it started running like a dog.
It was cutting out and stalling when idling. I checked for intake/vacuum leaks. I didn't find any... So I did a diagnostics check, and it came up with these codes.
181 - System lean right bank.
556 - Primary Fuel pump relay malfunction.
The fuel pump is pretty noisy. Even after the car is started. I bought a new fuel pump relay. But I have no Idea where the fuel pump relay is located. So I also want to know the location of that thing. Any Ideas?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 21, 2004
  • Mar 21, 2004
it might also be your fuel pump itself
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Mar 21, 2004
  • Mar 21, 2004
when i first purchased my car it would stall when i was slowing down to stop at a light. the computer showed both left and right bank (o2 sensers ) were bad. fuel pump was never niosey turn out that was the culprit it could not hold pressure. if it is hard to start after sitting for a while it could be the pump. check o2 first cheaper if that the prob.
Zero Signal
2,633
Tucson, AZ
Mar 22, 2004
  • Mar 22, 2004
If the pump is noisy, it's probably it. Get a fuel system guage from the autoparts store and see if it has hold pressure. Not only that, you may have a loose or frayed wire somewhere that might be cutting the fuel pump's power sporraticly and sending codes. The O2 sensor codes will come on any time it's lean, so fix the pump problem first and hopefully the O2 codes will go away.
I'd say there might be a good chance that a bad electrical connection could kill your pump from cycling it on and off too much while there is a load placed on it. Gotta be carefull when you get those issues, since they can set off a long chain reaction of problems. I've never messed with our pump relay, I don't even know where it is.
I was getting O2 codes last week and a few days ago I changed the fuel pump and it fixed it. Too bad it didn't fix the EGR valve code
randomjoker
427
Oklahoma
Mar 22, 2004
  • Mar 22, 2004
SN95Oh said:
Car:
94 Mustang GT
3.55 Gears
Trickflow intake
Where the hell did you find a SN95 in Oklahoma? (I live in Oklahoma and I am going to be purchasing one in a month or so)
T
tcmustang
185
Columbus Ga.
Mar 22, 2004
  • Mar 22, 2004
I was about to post almost the exact question when I saw tis one. I am in the process of painting a customers car. But first he wanted to use my paint boothe to do engine work. I have a hydraulic lift to get cars up so I can detail under them.
So we installed Trick Flow twisted wedge heads, Trick Flow intake, 1.7 RR's.Long tube headers and Mac power chamber pipe and flow master 2 1/2" system.
Car runs like crap, have been checking things and posting questions for 2 weeks. Finally ran codes and got a 542, 543, 556 all fuel pump related, then customer says," oh I had a guy install a fuel pump just before I brought you the car" So I decided to finish the paint job and let him take it back to the fuel pump "Guy".
The fuel pump relay on cars up to 93 was under the drivers seat, not sure where they hid it on 94-95's
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
