fuel pump bad??? need your help!
  • Thread starter Thread starter Foxfan88
  • Start date Start date May 31, 2006
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 31, 2006
  • May 31, 2006
OK yesterday i was driving home from work, and as i was driving, the car started bogging real bad, like it was trying to die, but it couldnt seeing how it was going 55+mph. So it bogged, i would press the clutch, rev it up and it would smooth out. For the next five minutes, it would do it off and on. Then it stopped, i thought i may have been low on gas. When it started i had jsut drove over a bumpy bridge, so i thought the gas may have jumped up and the pump may have grabbed some air. i drove home, then to my 2nd job, without a hiccup, then as soon as i pull in a parking spot, the car dies and wont start. It just cranks.
Everything is hooked up and nothing changed, just wont start, like its not getting fuel or something. We put some gas in it, thought it may have ran out, but it didnt, it wouldnt start afterwards. Also inside the car, usually you can hear the fuel pump prime, well you cant really hear mine at all I think it went away. I had my dad turn the key while i held my ear against the carpet in the hatch and couldnt hear anything, if i did it was VERY VERY quiet.
car has 145k, this seem normal for the stock pump to go out??
HISSIN50
34
129
May 31, 2006
  • May 31, 2006
That's a ton of miles out of a stock pump.
I would put your meter on the fuel pump relay socket and note the values during the prime-out. If you have proper power distribution to the tank, the pump is likely (or wiring at the tank).
I would start with checking for spark real quick, as well as injector pulsing if feasible. Jrichker has the master list of things to check, and in what order.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 31, 2006
  • May 31, 2006
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
May 31, 2006
  • May 31, 2006
lol i bought a spark tester, found out i had no spark and then found the small red wire going to the coil was loose. pushed it back in a viola! car runs
thanks for the help guys!
HISSIN50
34
129
Jun 1, 2006
  • Jun 1, 2006
Hey man, I (and I bet JR too) applaud that you found it. I find that it's easy to get tunnel vision once an idea is planted - and guys chase the wrong systems for some time because of it.
Nice work.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 1, 2006
  • Jun 1, 2006
Nice work.
That's why the checklist starts with the spark items. No spark can mean that you don't have the items needed to turn the fuel on.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
