  • 2.3L (N/A & Turbo) Tech
Fuel Pump Issue
  • Thread starter Thread starter StangGrrLy
  • Start date Start date May 15, 2004
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 15, 2004
  • May 15, 2004
My fuel pump died the other day, I kinda saw it coming because it started making that nice whiney sick cat sound. So she gets a brand new pump and a new filter and I'm back on the road.
I seem to have this problem where I'll have things fixed, get the car back from the mechanic, it will work for a few days and then the problem comes up again. This happened with my starter and my rad, and now it's happened with the fuel pump again.
The thing worked fine for the rest of the day, it started perfectly about 4 times that day, but when I went to start it up the next morning, the pump was dead again.
So my question is, what do you guys think could have caused this? Me and my dad were thinking it was either the fuel pump cut-off switch or the fuse, seeing as it just got a brand new pump. Problem is, I can't find the cut-off switch to check it. I poked around through that hole in the back of the hatch and couldn't find the button. I can't find the fuse either, owner's manual says it's right by the starter relay on the fender, but I don't see it. Am I just blind or am I missing something? Or do you think I should just take it back to the shop and make them deal with it, seeing as they just fixed this problem like two days ago?
P
Pro-Hawk
971
West Texas
May 15, 2004
  • May 15, 2004
It sounds weird that it messed up for the second time from this shop and also did this on other things you had doen also I would try to rest set the pump first before I call them. The switch is located near the latch for the hatch ( lol) on the spare tire well is. If this doesn't work I would call the guy back up and see what he plans to do about this pump that was just installed. I would probly have your dad go with you or call for you since in todays world people still take adavantage of women with car troubles. I'm not saying you don't know anything about cars etc but they would be less likely to do it to a guy...sad but true
Asha'man
1,909
Denver
May 16, 2004
  • May 16, 2004
Like I told you once before, quit going to that mechanic.
Ash
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 16, 2004
  • May 16, 2004
LOL this is a totally different place and a different mechanic.
I made sure the cut-off switch was set, and the fuses and lines look OK, so all I can think of is that I got a bad pump. But how often does that happen?
Should be easily taken care of, only thing that pees me off is that I've been without my wheels for the entire weekend cuz the shop isn't open till Monday.
P
Pro-Hawk
971
West Texas
May 16, 2004
  • May 16, 2004
I would call them up Monday and ask what they plan to do about it, Or better yet have your dad call them up !!
Dr_EluSivE
2,155
Central Illinois
May 16, 2004
  • May 16, 2004
probably not the pump, Probably a bad relay that is failing intermittintly, as the relays start to go bad they will sometimes work, sometimes not. The can also "brown out" a pump by supplying a lower than normal voltage and actually damage the pump itself. Depending on year the relay will be under the drivers seat or in the IRCM box under the hood.
Dr.
freakintiger
310
Virginia Beach, VA :TAX CAPITAL OF THE WORLD!
May 16, 2004
  • May 16, 2004
Same thing happened to me. I just changed out my fuel pump(relay was fine opened and closed, harness passed a check, and fuse was fine)in my 93 2.3 N/A vert, and it started up that night just fine several times. Next morning I get in the car to go to work, and nothing. So I check the for pressure at the rail, none, then make sure I have a good connection on the neg battery cable(I removed it during the repair then replaced it),yes, then checked the harness connection by the tank, okay. Then I try cranking it again, nothing, then I get annoyed and work the key back and forth in the ignition several times. I then set it to the on position and hear my pump prime the system, then I attempted to start the car, she started right up and no problems ever since!
I should add I was praying for the car to start.
Hope that helps, I'm thinking my car's problem was in the ignition at the steering column, something sticking or corroded?
furvel
29
Ohio
May 16, 2004
  • May 16, 2004
Crap, my fuel pump has been singin' me a song for about 4000 miles now. Doesn't sound like a sick cat, more like a loud constant whine. The local Ford dealer swears it's normal, but I have had my doubts. Sorry I can't help you StangGrrLy, I'm just curious if your pump (or anyone else's for that matter) ever sounded like mine, and if it failed soon after.
J
jasoncarmony
37
Live wherever the Air Force sends me. Right now I
May 16, 2004
  • May 16, 2004
I have a fuel pump question. I've got an 88 2.3N/a vert and I think the fuel pump is going out. Does anyone have any suggestions as to what type I should get? I don't want to spend a whole lot, but I don't want trash either. Plus, any suggestions where I could get it.
I will give my car's symptoms and get your opinions as well. First of all, I am getting about 16 miles to the gallon, which majorly sucks. Second, when I am about 50 miles or so from empty, if I make a sharp turn, my car dies. I don't have to be going fast of slow, the car just dies going around corners when I'm closing on empty. Also, I have start up issues in the morning and it has even begun happening a little more regularly. I will start it up and it will die, then I retry and it seems fine.
Any ideas or suggestions would be great.
Dr_EluSivE
2,155
Central Illinois
May 17, 2004
#10
  • May 17, 2004
  • #10
ALL ford fuel pumps whine, its normal, Mine has whined for at least 55,000 miles.
Dr.
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 17, 2004
#11
  • May 17, 2004
  • #11
That's true, mine was always quite loud, it just started to be noticeably louder/yuckier sounding right before it crapped.
Well I just sent her away on the tow truck, I'll post up later today what ended up being the problem....whether it was mechanical incompetance or a faulty pump or whatever.
Lex
248
Halifax NS. Canada
May 17, 2004
#12
  • May 17, 2004
  • #12
I bet my little money I have its the fuel pump. To work then not work that quick makes me wonder . I seen it happen, but just perhaps I could be wrong. I love to hear what it is though. Keep us posted
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 17, 2004
#13
  • May 17, 2004
  • #13
I just heard back, it ended up being a faulty fuel pump. What are the f-in chances that the brand new pump would be faulty?
Lex
248
Halifax NS. Canada
May 17, 2004
#14
  • May 17, 2004
  • #14
Woo Hoo Points for me. I think I may have a faulty oil pressure switch, Well I hope.. anyways. It could be the oil pump or sending unit... So it just proves that new isn't always good ..
Q
quik87
161
florida
May 17, 2004
#15
  • May 17, 2004
  • #15
not sure if this is what caused your problem but theres 2 relays that i changed cuz my fuel pump wasn't working....theres one under the drivers seat and one in the passenger side kick panel area. actually it's pretty much under the right front speaker.....pita to get to. but i changed both out and it worked fine. i suggest when you get your car back.....switch these out just in case that was the problem.
stanatic
259
Los Angeles, CA
May 20, 2004
#16
  • May 20, 2004
  • #16
I had a new pump installed about a year ago. I've noticed for about the last 6 months that it has been making a whine sound. I didn't think too much about it, but lately when I'm warming up the car the rpm's drop here and there and it almost feels like the car wants to turn off. So I got out of the car to listen to the pump. I noticed that when there would be a dip in the sound of the pump, that's when the rpms would drop. Does that mean the pump is going south? What else would cause that whine sound to dip in pitch?
Keasbey
915
Montreal
May 20, 2004
#17
  • May 20, 2004
  • #17
Okay, first Taryn, for the fuse near the starter relay, check for a little box screwed up to this relay, after that check for medium/big yellow wire. This wire will separate in 5 little wires. After that, follow the 3rd wire ( not sure but I think it is the 3rd one) and check for a kind of black half-cylinder. It is supposed to be written Fusible 18 Ga. on it..
I know it was a faulty fuel pump.. but this info could be useful ya know!
P
Pro-Hawk
971
West Texas
May 20, 2004
#18
  • May 20, 2004
  • #18
No comment. Now did they replace it for free
StangGrrLy
Miss StangNet 2003
1,330
Regina, Saskachewan
May 21, 2004
#19
  • May 21, 2004
  • #19
Yeah I didn't have to pay for anything. It was still a huge pain in the butt though.
P
Pro-Hawk
971
West Texas
May 21, 2004
#20
  • May 21, 2004
  • #20
I bet anytime I'm out of a car for a minute I go insane
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • Mindseye007
  • Aug 16, 2026
Mindseye007
