fuel pump promblem?
  • Thread starter Thread starter wshI_hd_1
  • Start date Start date Oct 31, 2004
W
wshI_hd_1
94
paulding, ga.
Oct 31, 2004
  • Oct 31, 2004
Ok, heres the promblem...at idle and normal driving condition my fuel pressure is 40# but once i hit WOT the fuel pressure shoots down to 20#. Is this the fuel pump or can it be the FPR (billet adjustable).I have no idea what size pump i have but what size should i run with the mods in my sig? (also, i have 24# injectors if it helps)...
thanks in advance.
Stang8URMPRT
1,100
Daytona Beach, FL
Oct 31, 2004
  • Oct 31, 2004
Yes, it could possibly be your fuel pump. They are 90lph stock, which is good for about 300 hp. You look to be well over that with your parts. Go with a 190 or 255 and a new fuel filter. What seems to be happening when you go WOT and the fuel demand increases, your fuel pump cannot keep up with the demand, thus dropping pressure.
Nick
HISSIN50
34
129
Oct 31, 2004
  • Oct 31, 2004
but if the FPR is on the outs, you can have a 100 GPH pump running and the pressure will not be to spec (the FPR is returning too much fuel).
one can carefully crimp the return line to try to determine if the pump or FPR is at fault.
good luck.
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
