fuel pump running on
  • Thread starter Thread starter sjhm9102
  • Start date Start date Mar 27, 2009
sjhm9102
texas
Mar 27, 2009
  • Mar 27, 2009
the car wont start i tried to read the codes but the only lights on the dash is brake and battery no check engine light no blinks and fuel pump wont stop running when trying to start
HISSIN50
34
129
Mar 27, 2009
  • Mar 27, 2009
Does your CEL prove-out?
Did you jump the self test connector incorrectly, instead grounding the FP relay's coil? This allows the pump to run anytime the key is on.
sjhm9102
texas
Mar 27, 2009
  • Mar 27, 2009
no ii havent done anything to the car i just went out one mornin and turned the key and the fuel pump wouldnt stop priming and no start i tried the to pull the codes like it says here in the forum thats when i noticed i had no engine light at all its either the computer or the fuel pump relay
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Mar 28, 2009
  • Mar 28, 2009
Does it stay running even with the key out? If so get a new fuel pump relay.
sjhm9102
texas
Mar 28, 2009
  • Mar 28, 2009
no just with the key in the on position or start
HISSIN50
34
129
Mar 28, 2009
  • Mar 28, 2009
Again, does the CEL prove-out?
sjhm9102
texas
Mar 30, 2009
  • Mar 30, 2009
i dont know how to check the cel
sjhm9102
texas
Mar 30, 2009
  • Mar 30, 2009
i found it on search nm jrichker but its a test for early models with no engine light
1965GTFB
  • Mar 30, 2009
My '92 is doing the same thing. I'm about to post my testing results. Look for "I think my '92 EEC is bad" to see what I did and the replies I get.
HISSIN50
34
129
Mar 30, 2009
#10
  • Mar 30, 2009
  • #10
The same method works for the MAF cars as the SD (no functional CEL) cars. This is where you need to be starting.
Proving-out is when the various warning lights illuminate when you first turn the key on. This lets you know the circuit functions and the light is operative. If your CEL doesn't prove out, the bulb might be burned out. You can replace the bulb or use an alternate method of code retrieval.
sjhm9102
texas
Apr 5, 2009
#11
  • Apr 5, 2009
  • #11
going to the dealer monday 90$$ diagnosis ill let you know what happens besides gettin screwed
sjhm9102
texas
Apr 5, 2009
#12
  • Apr 5, 2009
  • #12
i tried th alternate method of code still nothin
HISSIN50
34
129
Apr 5, 2009
#13
  • Apr 5, 2009
  • #13
What did the dealership tell you?
I didnt see you answer the question about if your CEL functions at all, nor did you discuss issues you had with alternate methods of code pulling.
sjhm9102
texas
Apr 5, 2009
#14
  • Apr 5, 2009
  • #14
the cel does not prove out and the test light method doesnt work either the dealer just told me to bring it in imma try a different test light today it doesnt make any sence
HISSIN50
34
129
Apr 5, 2009
#15
  • Apr 5, 2009
  • #15
Some things to check if codes won't pull.
You will also probably want to replace the CEL bulb.
Good luck.
sjhm9102
texas
Apr 7, 2009
#16
  • Apr 7, 2009
  • #16
i decided to pull the computer and found a blown blue thing inside as well as some over heating ill have to do more research on why this happen
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
E
Pats antiitheft-bypass (ez fix)
  • ETindall
  • May 19, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 19, 2026
ETindall
E
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
