Fuel Pump Screaming
  • Thread starter Thread starter Tim Sisk
  • Start date Start date Jun 21, 2015
T
Tim Sisk
21
  • Jun 21, 2015
My car has been setting alot and today I started it and everthing was fine and all of a sudden the fuel pump started screaming everthing still runs fine what do i need to check
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 21, 2015
  • Jun 21, 2015
Sounds like the pump is on its way out. Original?
T
Tim Sisk
21
  • Jun 21, 2015
T
Tim Sisk
21
  • Jun 21, 2015
No its a ford racing 255
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 21, 2015
  • Jun 21, 2015
It its screaming, there's a good chance that it's gotten something in it. Perhaps the strainer has come off. It's been known to happen.
How much fuel is in the tank?
T
Tim Sisk
21
  • Jun 26, 2015
1/4 tank of fuel, but got my fuel pressure set at 38lbs it only builds 30 and will not hold pressure,fuel bad or you think it's got trash in it, I'd like to save it if I could
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 28, 2015
  • Jun 28, 2015
Check fuel pressure:
The local auto parts store may rent or loan a fuel pressure test gauge if you don't have one.
Disconnect the vacuum line from the fuel pressure regulator. Check it for evidence of fuel present in the line by removing it and blowing air through it. If you find fuel, the fuel pressure regulator has failed. Reinstall the line; leave the fuel pressure regulator end of the vacuum line disconnected. Then cap or plug the open end of the vacuum line and stow it out of the way.
Connect the fuel pressure test gauge to the Schrader port located just behind the alternator.
Turn the ignition switch on & start the engine. Observe the pressure: you should see 38-41 PSI at idle.
Turn the ignition off; reconnect the vacuum line to the fuel pressure regulator. Then disconnect the fuel pressure test gauge. Watch out for squirting gas when you do this.
Fuel pump pressure test
Disconnect the larger of the two fuel lines up by the Schrader valve. It is the return line and does not have the Schrader valve on it. Find a piece of rubber fuel hose and clamp it on the return line coming from the regulator. Stick a bolt in the other end of the hose and make sure that all your connections are tight and leak proof as possible. When this powers up, you don't want fuel squirting everywhere. Hook up the fuel pressure test gauge. Turn the ignition switch on and watch for leaks. You may want to use a helper inside the car to cut the switch off quickly if you have a leak. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
Caution!!! You have blocked the return line for the fuel pump! Pressure will rise very quickly past safe levels with a good pump
If the pressure goes up past 55 PSI, the pump is good and the fuel pressure regulator is bad. If the fuel pressure does not hit 55 PSI or more in a few seconds, the pump is bad or you have electrical problems.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
