  • 1994 - 1995 Specific Tech
Fuel Pump?
  • Thread starter Thread starter otis
  • Start date Start date Feb 21, 2006
O
otis
115
Alberta
Feb 21, 2006
  • Feb 21, 2006
Can a fuel pump that is supposedly starting to give troubles but does not casue the check engine light to come on (and the car seems to run fine) send a code to signal its faulty?
HISSIN50
34
129
Feb 21, 2006
  • Feb 21, 2006
I dont get it. What code are you getting or expecting?
A weak pump could cause a lean code.
O
otis
115
Alberta
Feb 22, 2006
  • Feb 22, 2006
They never told me the code at the dealership. My check engine light just came on the other day and the car managed to die once while ideling but now the car runs fine and no check engine light, so I took it to the dealership just to get checked out and now they say codes came up showing it needs an egr sensor, egr valve and a fuel pump. I just can't see the car needing all that when it seems to run fine again and the check engine light has not returned. I think they are just searching for something because when I questioned about the pump they said they thought I could get away without replacing it. Just thought I would check to see if a failing pump would even through a code, I didn't think it would, especailly when there is no check engine light.
HISSIN50
34
129
Feb 22, 2006
  • Feb 22, 2006
The electrical side of a pump is where the codes come up (primary or secondary electric codes), but generally not pump flow, since the computer doesnt monitor it, per se. Like I said before, a lean code can indicate a weak pump, but other things can cause that code also. The thing with codes is that they give us an area to search, but dont absolutely tell us what component is at fault.
WIth the EGR, I might clean it and use a meter to see if the EVR is calibrated. Then see what codes pop up in the future. FWIW, if the EGR fails (doesnt open at part throttle), it can cause a leanness at part throttle, which could pop a lean code. And if the EGR opened at idle, it could cause a rough idle or stalling. Again, the deductive process at work. Diagnostics are needed to know better.
And you can pull your own codes with a paperclip if you desire (I like to actually see the codes myself). As enthusiasts, we might try and clean a component, rather than replace it. I understand the dealer (or a shop's) perspective - they dont want a come-back, so they tend to be a little broad in their diagnoses sometimes. I would do the same if I had a shop.
Anyhow, post more info and we can help.
Good luck.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
