Fuel pump
  • Thread starter Thread starter GSXRMIXXER
  • Start date Start date May 28, 2006
GSXRMIXXER
97
  • May 28, 2006
i just recently gutted my interior and now when i turn the key over the fuel pump dosnt come on. is there a ground somewhere in the interior i may have disconnected? where should i start troubleshooting?
GearHd6
459
Ashford, CT
May 28, 2006
  • May 28, 2006
The little relay bolted to the floor under the drivers seat HAS to be hooked up. It kills the pump in case of a wreck or an extreme angle.
GSXRMIXXER
97
  • May 28, 2006
damn thanks. i know it was a newbe question but thats what this forums for... thanks again.
GSXRMIXXER
97
  • May 28, 2006
damn i cant find that piece that was under the seat is there any way to rig the wires to make them think its there????
GSXRMIXXER
97
  • May 28, 2006
HISSIN50
34
129
May 28, 2006
  • May 28, 2006
The Fuel pump relay is under the seat on foxes until about the last year - they moved to the engine compartment at that point (next to the WOT relay).
The fuel pump relay doesnt care how it's mounted - it is just a relay. The inertia switch in the trunk is what is the safety precaution in the event of a collision.
Feel around under the seat and carpet for the relay wiring harness and socket - remove the seat if necessary.
You dont want to hamburger together the fuel pump circuit to make the car run (and no, there is no ground wire bolted to anything, so dont sweat that thought).
Good luck.
GSXRMIXXER
97
  • May 28, 2006
well heres the thing. i gutted the interior and accidentally threw away the relay. i was wondering if there was a way to wire it in order to make my car run without it?? by the way its a 89GT. i remember removing the relay when i ripped the carpet out but i must of threw it away if the junk yard is open tomorrow im gonna try and grab one. is that my best bet?? or is there a way i can run without it??
HISSIN50
34
129
May 29, 2006
  • May 29, 2006
You can get a new relay from Ford ($$) or at the auto parts store. I'm pretty sure Sorenson is one company who makes one that works.
You could jump the relay but it's not the smartest move (jumping the common and Normally Open terminals). I'd hit the J/Y, dealer or parts store for the right part.
FWIW, the WOT relay should be the same part number if you want to make sure the car starts right now.
Good luck.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
  • brandyn200
  • Jun 20, 2026
AeroCoupe
