Fuse link help? Car wont start
  • Thread starter Thread starter matador91
  • Start date Start date Jul 16, 2008
matador91
107
31
38
Bothell
Jul 16, 2008
  • Jul 16, 2008
We've checked the inertia switch and there is no power. Then we checked the fuel pump relay and had 12volts, now I'm thinking it's the fuse link, but I have know idea what that looks like, or even what it is. Please help
LiquidGT
368
Near STL hell
Jul 16, 2008
  • Jul 16, 2008
The fuse links are short lengths of special wire on the starter solenoid, they look like regular wire for the most part, but the gauge is a little smaller than the circuit they protect. They'll usually burn up, so its pretty obvious if they're bad.
HISSIN50
34
129
Jul 16, 2008
  • Jul 16, 2008
You didnt note what you jumped at the relay to make the pump work. Depending upon the year of your car/harness, the inertia switch is either on the control or load side of the circuit.
On earlier models, the link for the load side is 18 gauge, connected to an orange/lt blue wire.
Simply stated, if you have one terminal at the FP relay with constant power and another that shows key-on power, the links should be ok for the circuit.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 16, 2008
  • Jul 16, 2008
No info about your car's model year, EFI or carb, no mods listed. Makes it hard to troubleshoot when we don't know what you have.
Therefore, no clue as to which wiring diagram you need. The wiring changed several times between 79 & 95.
That's why it is a good idea to use the sig under the user control panel (User CP) option. It allows you to post your car year & mods, which help greatly when troubleshooting things. No, it is not there for us to snoop and see any "Secrets" you have hidden away under the hood. Be a good stangnetter and update you sig for future reference & don't keep us guessing.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
