Gas leak? Why??
  • Thread starter Thread starter PhLoBuS
  • Start date Start date May 6, 2005
PhLoBuS
473
Beverly, MA
May 6, 2005
  • May 6, 2005
Alright so I recently installed:
-Trickflow Street Heat Upper Intake
-Trickflow Lower Intake
-Replaced a bunch of old vaccuum lines
-Accufab 75mm TB
I recently finished installing everything, made sure everything was tight even stuff I have not touched recently. I go to fire up the car and since there is no pressure I did not expect it to start up instantly. So I turned the key for a couple seconds. Let off, did it a 2nd let off, and finally the third time. Then I heard a pop and then fluid leaking which led to be gasoline. A good amount too, but it finally stopped after 30 seconds. From underneath the car near the oil pan it was leaking not near the injectors or the engine bay. If anyone has heard of this or had this problem please post any information, my car has not been working for awhile because I have been busy and the weather has been poor lately. Thanks!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 6, 2005
  • May 6, 2005
Did you disconnect the fuel lines? If so it could be a bad O-ring or spring not holding the fuel. Or did you just push the rail out of your way while installing the new intake? If so, you probally bent a metal part or you just put a little too much stress on the old lines. Next time, I would suggest disconnection them with the proper tool and inspection the O rings before install.
PhLoBuS
473
Beverly, MA
May 6, 2005
  • May 6, 2005
I used the proper tool, fuel line disconnect tool. I have two of them and used them, I replaced the orings for the fuel rails and fuel injectors so thats not the issue
90mustangGT
2,773
17
89
Dallas, GA
May 6, 2005
  • May 6, 2005
Pinpoint the leak.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
