  • SN95 4.6L Mustang Tech
Gauge install help
  • Thread starter Thread starter deftsound
  • Start date Start date Dec 25, 2005
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Dec 25, 2005
  • Dec 25, 2005
Well santa brought me two autometer phantom gauges (water temp and oil pressure) and a cluster gauge pod. My question involves how to install the gauges. I installed the same two on my old 91 gt but im not really sure how to install them on the 99. Is there a write up somewhere on how to do it? Im just not sure exactly where the coolant sensor thing would go and how i would keep the stock gauges functional. Im also not sure exactly where the oil pressure sensor would go. A part list would also be nice...
deftsound
Apr 6, 2004
945
Texas City TX
Dec 25, 2005
  • Dec 25, 2005
bump
sgarlic
3,085
Dec 26, 2005
  • Dec 26, 2005
Do a search and you'll find everything you want to know. Locations, which wires to use for power, dimmer, etc.
saleen556
387
Hillsboro,OR
Dec 26, 2005
  • Dec 26, 2005
This link should help. http://www.modularfords.com/forums/...nd-eng-temp-electric-gauge-install-34631.html
deftsound
Apr 6, 2004
945
Texas City TX
Dec 27, 2005
  • Dec 27, 2005
i tryed a search and couldnt find what i wanted. Thanks for the link though!
deftsound
Apr 6, 2004
945
Texas City TX
Dec 27, 2005
  • Dec 27, 2005
are there any other article links? Its nice having 2 different references
deftsound
Apr 6, 2004
945
Texas City TX
Dec 28, 2005
  • Dec 28, 2005
im havin trouble identifyign where to put this coolant an oil sensor
saleen556
387
Hillsboro,OR
Dec 28, 2005
  • Dec 28, 2005
The oil pr sensor goes in the oil filter base.There should be an allen plug there.The coolant temp sensor goes on the left side of the engine up near the front.I think there is a pretty good pic in that link.
deftsound
Apr 6, 2004
945
Texas City TX
Dec 28, 2005
  • Dec 28, 2005
anyone have any idea what size the t fitting needs to be so you can use your stock gauge and the aftermarket one
sgarlic
3,085
Dec 28, 2005
#10
  • Dec 28, 2005
  • #10
1/4" NPT T fitting, 1/4" close nipple, and the 1/4" -> 1/8" adapter that comes with the gauge.
deftsound
Apr 6, 2004
945
Texas City TX
Dec 28, 2005
#11
  • Dec 28, 2005
  • #11
ok so the t fitting needs to be 1/4 on all 3 sides?
sgarlic
3,085
Dec 28, 2005
#12
  • Dec 28, 2005
  • #12
http://www.sgarlic.com/04stang/oilgauge.html
deftsound
Apr 6, 2004
945
Texas City TX
Dec 28, 2005
#13
  • Dec 28, 2005
  • #13
ok this is makin no sense. on the bottom of the oil filter i see a electrical snap plug thing with a wire coming out of it but i dont see any other places where their is a plug like the one you are describing. I dont know if its different on 99's or something...
thats why i asked what size T fitting i needed..
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Dec 28, 2005
#14
  • Dec 28, 2005
  • #14
hummm I like to get oil pressure and water temp on my car as well...
deftsound
Apr 6, 2004
945
Texas City TX
Dec 28, 2005
#15
  • Dec 28, 2005
  • #15
i ****ing hate that god damn ****in bolt that wont come out for the water temp gauge ****in thing god damnit
whyask
735
Sacramento
Dec 29, 2005
#16
  • Dec 29, 2005
  • #16
1/4 on all three sides,
sgarlic
3,085
Dec 29, 2005
#17
  • Dec 29, 2005
  • #17
I could be wrong, but I was under the impression that all the romeo's have the extra spot. It's on the bottom. Look upward at the bottom of the vehicle. If you have one, you'll see it. It's a hexagon shaped plug about 3/4" around, sitting on the bottom of that whole assembly where the oil filter, oil pressure sender, etc, go.
Look on my site, the link I posted, and look at the picture. That clearly shows where it goes. If you look at your car, and compare it to the picture, and there's no plug on your car, then you don't have one.
If that's the case, then just get the friggen T fitting. This isn't rocket science.
deftsound
Apr 6, 2004
945
Texas City TX
Dec 29, 2005
#18
  • Dec 29, 2005
  • #18
oh i thought it was rocket science
sgarlic
3,085
Dec 29, 2005
#19
  • Dec 29, 2005
  • #19
You know what, nevermind. Everyone in this thread has gone out of their way to provide not only links, but also information to you. You obviously refuse to listen to the advice people are giving, and obviously are not reading the links we posted, and still haven't done a search like we recommended.
I'm done with this thread. Good luck to you.
deftsound
Apr 6, 2004
945
Texas City TX
Dec 29, 2005
#20
  • Dec 29, 2005
  • #20
actually your wrong, i have looked at every link and taken every bit of advice you guys have given me seriously. Obviously i have ran into some complications because mine is a 99 and does not have the same factory t fitting yours does. When you post a comment like, 'its not rocket science' its asking for a retort so dont get mad.
Dont think im not taking you guys seriously because i am. I spent atleast 3 hours screwin with it last night and ive ran into a few complications
1) i cant get the damn plug out of the block for the water temp sensor
2) i cant screw that T fitting into the stock oil pressure sender location because a wire harness is in the way, so im in the process of removing the starter cable which has turned into a huge hassle. As of right now its soaking in wd40 to try to get it to loosen up a little.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
  • dan50
  • Jul 18, 2026
dan50
Issue please help
  • 4.6andre
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
