  • SN95 4.6L Mustang Tech
Gauges Maxing out at Startup
  • Thread starter Thread starter LouisianaZJ
  • Start date Start date May 31, 2009
LouisianaZJ
237
May 31, 2009
  • May 31, 2009
Last time I fired up the GT, the speedo & RPM gauges both maxed out, went to zero, then went to actual reading.
I have started it up since then, and all was normal again.
What is going on here?
V_Eight
617
ATL
May 31, 2009
  • May 31, 2009
That happens if you reset the computer by unhooking the battery for a set number of minutes. Why it randomly happened to you I do not know.
LouisianaZJ
237
May 31, 2009
  • May 31, 2009
I read this may also be due to a dying battery. The wierd thing is I just recharged the battery (trickle) about 3 weeks ago.
I will double check the cables at the battery
blubullett
535
Modesto, CA
May 31, 2009
  • May 31, 2009
Mine does it if my battery is low or one of the terminals is loose or something.
joshjwc9
1,095
17
39
Palm Harbor, FL
May 31, 2009
  • May 31, 2009
The batteries cold start abilities are starting to go down the toilet. I am guessing it is probably kind of old, or you have something that has a substantial draw on it, like a sound system.. etc.
Go buy a new one before you resort to daily jumps and hoping it will start. I would bet that the car feels as though it starts faster as soon as you replace it.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 31, 2009
  • May 31, 2009
This sounds right on the money to me. Its a warning when the gauges do that to let you know to replace the battery. The other gauges should be doing it as well, oil, fuel, temp, ect.
Kraw
Nail On The Head El Moderatoro
ATL via MSY via MLU via Pitkin, La
Jun 3, 2009
  • Jun 3, 2009
ditto.. It was an earlier indicator my batt was dieing. Had to change it a few weeks later
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
