  • SVT Tech Forum
gear guide
  • Thread starter Thread starter cobra dave
  • Start date Start date May 4, 2004
cobra dave
308
  • May 4, 2004
Looking to find a start to finish guide/instructions on a rear-end gear swap for a 96. I know once i start i'll space something. I appreciate it.
C
chrisbudl1
436
springfield MO
May 4, 2004
  • May 4, 2004
I don't have a walk through, but I just did it two weeks ago. send me a pm. and I'll tell you what I know. It was fairly simple though.
9
97rmcobra
118
Milford,MA
May 5, 2004
  • May 5, 2004
Richmond Gear company has a video on a general rebuilt. Also the Ford factory manual has good detail.
C
chrisbudl1
436
springfield MO
May 6, 2004
  • May 6, 2004
from what I can remember, be careful with the abs sensors, they are plastic, and will break, you will need a specific size socket to get the driveshaft disconnected from the rear end. We reused all of the factory spacers on my 97, a machine shop will come in handy removeing the bearing off of the pinion shaft, hopefully it's close so they can press the bearing on the new shaft, and you might as well get a new one, while you are in there. I can't say for sure that the spacers will work on yours like they did on mine. We also reused the crush collar, and tightened everything together until it was pretty snug, there was a little play with the pinion shaft no more than an 1/8 of an inch though. I am glad that everything worked out, it made me nervous as f#@* until I finally got to get on it, than WOOHOO!!!!!!!! Good luck be prepared to want to shift in to 6th gear, oh wait we don't have one. Well worth it though.
9
97venum
  • May 8, 2004
Check out this thread for gear swap info
Pretty good details with photos: http://forums.stangnet.com/showthread.php?t=429117&referrerid=66941
A
S197 2 piston front caliper dimensions
  • AussieDavid
  • Mar 26, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 26, 2026
AussieDavid
A
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
M
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
  • SVT Tech Forum
