You can cap them and the manifold barbs off. The EGR might still be hotter than the coolant any that point, but it was not a problem on the ‘91 I fixed up. The main thing is to not use vacuum caps on the manifold barbs. The are not reinforced and soon leak under pressure and cut under a clamp.So does the egr spacer need the coolant hoses ? It never gets cold here in Nevada.If I by pass them do I just use a hose connecting to both sides ?
The plate can de ice and cool on the same days in some states.Or plug in the back of the intake and JB weld and hammer and dolly to flatten the barb on the heater tube.
I though the coolant through the egr plate was to 'cool' the recirculating exhaust gases.
Meh, what do I know
Mac throttle bodies also had a whistle to them, my buddy had one on his 92 LX and it was noticeable for sure.The only issue I've heard of with BBK throttle bodies is their tendency to whistle at or near idle.
I've read you can remedy this by drilling a small hole in the butterfly plate.
I have a 75mm BBK and yes occasionally it will whistle just off idle but never enough to bother me
some day I may drill it.
