At WOT, the air/fuel ratio is a function of fuel pressure, RPM, airflow through the MAF (mass air cars only) and the TPS. The O2 sensors don't have any control input into the computer's program at WOT.
Therefore you can use the SOP meter...
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have you buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in. Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
I want a consistent 13:1 air fuel ratio. How can I get that. I don't think an FPR can do it all the way across. Maybe it can. That's where you guys come in.
I have under $1000 into my tuning stuff ($770 to be exact ) I got a good deal on a used PMS and a very good deal on an innovate motorsport LM 1 wideband (bought brand new, not used)
That's what I want, but don't have the money. I gotta $850 dent to fix too that insurance isnt gonna cover. Probably have to get it repainted and drive it primered until then.
Hey, thanks for that. I've seen them and heard good things about them. Didn't realize they were as cheap as they are. Appreciate it. Still be a little while before I can get it though.
