Hard Start After Car Is Hot
  • Thread starter Thread starter 9150LX
  • Start date Start date Jun 16, 2012
9150LX
363
Squamish, B.C
Jun 16, 2012
  • Jun 16, 2012
Heres whats been happening lately.
First start up of the day or any time after its had time to cool down, its will start normally. But if I drive from my house for 5 minutes and turn it off to get gas, it struggles to start. It sounds like the starter is struggling to spin (drawing a lot of current). The battery is fine as I tried it in other vehicles and had no problems. The more I try when hot, the less it will turn over. Once there was even some smoke coming out of the defrost vent on the passenger side from repeatedly trying to start it while hot, leading me to believe it is starter related.
Any suggestions? I have no clue where to start looking for shorts......
ratio411
3,870
73
109
Pensacola FL
Jun 17, 2012
  • Jun 17, 2012
Yeah, it's probably your starter...
If you had made any changes to it lately, like tuning or headers, you could look at timing or headers being too close the starter, causing heat soak, but if none of these things have been modified around the time it started, then there isn't much else to suspect. You might check all your grounds and major connections at the battery, solenoid, starter, etc... Just as a cheap way to feel warm and fuzzy about spending money on a new starter. But IMO you'll be buying a new starter soon.
Dino Dino Bambino
1,673
90
79
Cyprus
Jun 17, 2012
  • Jun 17, 2012
Yeah that does sound like starter heat soak to me. If you have the time and the tools, I suggest you pull out the starter, strip it down, clean the insides, and replace the brushes. When you reinstall it, cover it with a DEI heatshield to keep exhaust heat away.
Reactions: Gearbanger 101
9150LX
363
Squamish, B.C
Jun 17, 2012
  • Jun 17, 2012
Well, I barely ever drive the car. Usually a couple permits a year, so its hard for me to pin point when it started to happen, but i dont remember changing something then it starting to have issues. The battery is relocated to the trunk via Taylor relocation kit, so I have all good wiring/cables. Battery is grounded good to the frame of the car. The solenoid was my other suspect. Seems to me like it has A LOT of wires (5-6) running to the + terminal. I am only able to thread the nut on the first thread and thats it. What other grounds should i be looking for?
ratio411
3,870
73
109
Pensacola FL
Jun 17, 2012
  • Jun 17, 2012
I had a car with the battery in the rear, and I always had heat soak issues. No matter age/condition of starter.
Some things that supposedly help with trunk mount battery starting issues:
Extra ground cable run to the front of the car, under a starter bolt. (In addition to the cable going to rear subframe)
Starter solenoid moved to the trunk.
Extremely regular cleaning and retightening of all electrical connections at battery, grounds, starter, solenoid, etc...
Heat sheild for the starter, as any heat, on any eletrical motor, in any condition, raises the amperage draw.
Higher amperage battery.
Gear reduction starter
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 17, 2012
  • Jun 17, 2012
My guess is that the starter is on it's way out. Follow Bullitt95's directions and try backing the timing off a degree to see if that makes a difference. Also, as ratio411 stated....extra grounds are never a bad thing.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 17, 2012
  • Jun 17, 2012
OBefore you spend a lot of time/ money chasing this, pull both the starter and the battery and have both tested at the local auto parts store. I spent a lot of money and time chasing a hot start issue, and I was convinced my battery was good because it read 12+ volts on my DMM. Turns out the battery was actually on it's last leg and while it seemed good, it actually had huge voltage drop during cranking and was very weak. I upgraded cables, added grounds, retarded timing, and even thermal wrapped the exhaust, but nothing fixed it until I replaced the battery.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 17, 2012
  • Jun 17, 2012
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Rear Mounted battery wiring
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10 gauge wire they recommend is even less adequate that the stock Mustang wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/2" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug there is a green wire. It is the sense lead that turns the regulator on when the ignition switch is in the run position. Cut the green wire and solder the 40' of green wire between the two pieces. Use some heat shrink to cover the splices. See http://fordfuelinjection.com/?p=7 for some excellent help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire. Try to run the green wire inside the car and protect it from getting cut or chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs. Do not add the jumper between the 1/2" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies a turn on signal to the regulator when the ignition switch is in the Run position. Turn the Moroso switch to off, and the sense voltage goes away, the voltage regulator shuts off and the alternator quits making power.
The fuse & wiring in the following diagram are for a 3G alternator. The stock alternator uses a dark green fuse link wire that connects to 2 black/orange wires. Always leave them connected to the starter solenoid even if you have a 3G alternator.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
Rear mounted battery ground wiring. Follow this plan and you will have zero
ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot
on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the
rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean
shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to
the chassis ground where the battery was mounted up front. Use a 5/16” bolt
and bolt down the 4 gauge engine to chassis ground, make sure that it the metal
around the bolt is clean & shiny. This is the alternator power ground.
The computer has a dedicated power ground wire with a cylindrical quick connect
(about 2 ½”long by 1” diameter. It comes out of the wiring harness near the
ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground
in the same place as you bolted the alternator power ground. This is an
absolute don’t overlook it item for EFI cars
Note: The quick disconnect may have fallen victim to damage or removal by
a previous owner. However, it is still of utmost importance that the black/green
wires have a high quality ground..
Picture courtesy timewarped1972
Crimp or even better, solder the lugs on the all the wire. The local auto stereo
shop will have them if the auto parts store doesn't. Use some heat shrink tubing
to cover the lugs and make things look nice.
Reactions: krazedstang
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Monday at 12:38 PM
Fox 5.0 Mustang Tech Tuesday at 7:31 PM
mikeah
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
