Hard starting
  • Thread starter Thread starter raleighstang65
  • Start date Start date Aug 30, 2008
raleighstang65
170
Wake Forest, NC
Aug 30, 2008
  • Aug 30, 2008
Took the wife out for a ride this morning and stopped for breakfast. When we went back out 30 mins later we had trouble getting it to start. I could hear the starter turning and the battery isn't dead. It has a new solenoid, new Ford Racing mini starter and new alternator.
I searched on here and read about the starter getting hot from headers possibly causing slow hard starts after its hot, I do have headers. But with a mini starter the headers aren't really that close to the starter. I finally got it started and it ran like normal after that. Any thoughts on what could have caused this?
I realized that most of my drives are out and back home without stopping so I'm not sure if this is something that would normally happen if I made some stops while I'm out or if it is something new.
woodsnake
1,352
15
69
Hicksville, NY
Aug 30, 2008
  • Aug 30, 2008
Dirty battery terminals, corroded power cables from the battery to the block/ starter.
Basically, insufficient ground.
wild70stang
317
  • Aug 30, 2008
If the starter turns the engine at the same RPM during these hard starts, its probably the fuel boiling in the carb. Happens to me all the time if I let the car sit for 45-60 minutes when I have reached operating temps. If you think its other stuff just go over the basics to see what might be worn.
10secgoal
2,801
San Diego
Aug 31, 2008
  • Aug 31, 2008
Stick a small phenolic spacer in there or a really thick gasket. That'll keep a lot of heat out from the intake.
raleighstang65
170
Wake Forest, NC
Sep 2, 2008
  • Sep 2, 2008
So if it doesn't sound sluggish when it's trying to start that would mean it's probably not a bad ground and more likely fuel boiling in the carb? I do need to replace the ground cable from the battery to the block but the battery terminals are crud free.
I do have a spacer between the carb and the intake.
Hack
1,945
Minneapolis
Sep 2, 2008
  • Sep 2, 2008
If the starter is still spinning fast it's the fuel boiling in the carb or the fuel lines.
65fastbackresto
1,229
AR
Sep 2, 2008
  • Sep 2, 2008
Fuel boiling?
IOs that what was called vapor locking when I frew up? Mine does it too, cept it`ll do it after the motor gets good and warm even before I kill it.
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
SN95 V6 Mustang Tech May 22, 2026
PNN
P
