  • SN95 4.6L Mustang Tech
Has anyone swapped a Cobra T-45 into a GT 1997?
  • Thread starter Thread starter mustangjim365
  • Start date Start date Apr 23, 2010
M
mustangjim365
12
  • Apr 23, 2010
I have a 97 GT and need a transmission, 5 speed.
I have found a reasonably priced 5 speed the only issue is the replacement is from a Cobra 1381-002. My tranny is a 1381-001.
My research ion TTC Automotive shows the only difference is the Cobra tranny has the crossmember bolting location 97.9 mm (3.85 inches) further back on the transmission.
Has anyone installed a Cobra trans in their GT? How did you overcome this issue? short of moving the crossmember brakcets back the additional distance?
Thanks
Jim
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 24, 2010
  • Apr 24, 2010
they are the same. it will bolt up with no issues
M
mustangjim365
12
  • Apr 24, 2010
Thanks for the response.
So you are saying there is no difference in the location on both trannys where they bolt up to the crossmember?
Jim
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Apr 24, 2010
  • Apr 24, 2010
i'm pretty sure there is not a difference. i have never heard of anything being different other than the crossmember for the 03-04 cobra with the T56
edit***** what year is the cobra trans? 99 and up has an electric speedo. that may be the difference. what prices are you getting?
M
mustangjim365
12
  • Apr 24, 2010
The trans is out of a 96-98 Cobra. Priced at $400.00
Modern Driveline - T5 Transmission Conversion Specialists Mustangs, Falcons, Cobra's, Tigers...
Is there a difference between a GT T-45 and a Cobra T-45 from 96-97? [/B]
Yes there is, but it is small. All the GT T-45 had 8 tooth speedo gears and the crossmember mounting location is more forward as compared to the Cobra's. In later years, they became the same location. All other parts are the same.
http://www.ttcautomotive.com/English/onlineorder/pdf/install_dimen_T-45_169.pdf
I have seen some postings saying you can swap the GT tailshaft onto the Cobra tranny and solve the crossmember issue and do the same for the 99 trannys....to solve the speedometer issue???
thanks
Jim
M
Midnight2V
224
Oklahoma
Apr 24, 2010
  • Apr 24, 2010
I am almost positive you need to either swap the gt tailshaft over or swap in a cobra crossmember. It doesn't matter which so long as you do one of them.
M
mustangjim365
12
  • Apr 27, 2010
thanks, i am currently weighing my options..
jim
M
mustangjim365
12
  • Apr 29, 2010
Good news.
I found a T-45 from a 96 Mustang GT for 300.00 within 25 miles of me.
I picked it up last nite.
I plan on having a transmission shop check it out prior to installing it.
Any tips?
thanks
Jim
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
J
Electrical 2008 GT Automatic to Manual Swap - No Crank
  • jayden2013
  • Mar 14, 2022
  • 2005 - 2009 Specific Tech
4K
2005 - 2009 Specific Tech May 21, 2024
JBattle463v
J
F
1993 Cobra flooding
  • FireFoxCobra_SVT93
  • May 20, 2022
5K
Fox 5.0 Mustang Tech Mar 11, 2023
nickyb
