Have fun with this one!!!
  • Thread starter Thread starter Beef97
  • Start date Start date Aug 11, 2005
First Prev 2 of 2
Beef97
46
Corpus Christi, Texas
Aug 14, 2005
#21
  • Aug 14, 2005
  • #21
yeah timing chain was installed ok.....i had the overheating problem also just before i changed it....i just re-adjusted the valves today and going to switch the rubber fuel hose over to stainless steel braided hose to maybe help keep some of the heat out. thanks for the ideas!
66Runt
680
Aug 14, 2005
#22
  • Aug 14, 2005
  • #22
Does your distributor have vacuum advance
The reason I ask, is that if you are getting pinging under light load, it could be the vacuum advance needs adjustment, or it is connected to the wrong vacuum source.
If not I'd suggest you graph your advance, and like D. Hearne said check to insure your timing is not coming in too quickly.
That pinging will definitely cause overheating. In fact if not taken care of it will eventually cause piston failure.
First Prev 2 of 2
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • brandyn200
  • Jun 20, 2026
AeroCoupe
