Have I installed the wrong Headers?
  • Thread starter Thread starter jim7485
  • Start date Start date Oct 12, 2006
J
jim7485
64
Michigan
Oct 12, 2006
  • Oct 12, 2006
66 Mustang with FRPP 302 crate motor w/GT 40 aluminum heads. We installed Hedman shorty headers, part no: 88400. The bolt pattern is fine, but there seems to be a fair amount of overlap, enough that I think flow may be restriced. The engine dude (more of a body man) told me it was normal, but I'm concerned. The car runs fine, but seems to lack power. Wondering if these headers are restrictive due to the overlap. They are correct for a 66-73 302. Question is: are they correct for GT 40 heads? I'm considering a switch to FMS-M-9430-P51 which I know are correct. Any thoughts? http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&N=+115&searchinresults=false&Ntt=FMS%2DM%2D9430%2DP51
Thanks
jim
brianj5600
1,964
Middle TN
Oct 12, 2006
  • Oct 12, 2006
I would contact Hedman.
88dragtop
198
Glastonbury,CT
Oct 12, 2006
  • Oct 12, 2006
I assume by overlap you mean the exhaust port on the header flange is smaller than the port on the heads? Even so I wouldn't think it would be as bad as a manifold. Hard to say it's losing power with the butt meter, dyno or 1/4 times would give you a better idea. Those FMS are late model headers and won't fit the early engine bay.
T
truck90278
382
Redondo Beach, CA
Oct 12, 2006
  • Oct 12, 2006
We're running the Hedman Elite with no problems. We initially had the GT 40 Aluminum heads and switched to Edelbrock Performer heads - no problems either way - no lack of power
Reactions: Metalgearmoogle
BullittStangV8
1,104
NJ
Oct 12, 2006
  • Oct 12, 2006
Is it casting flash that could be ground down? Or simply the ports dont match up with eachother? (meaing part of the head port is covered, and the header tube extends part the port in the head)
J
jim7485
64
Michigan
Oct 12, 2006
  • Oct 12, 2006
More info....
A bit of clarification: The bolt pattern is perfect but the header flange holes do not match the ports. They are roughly the same size, but offset somewhat, perhaps 1/3 of each port is covered by the flange. Can I get some confirmation on an additional issue? Will the FMS-M-9430-P51 headers (which I know are correct for the GT 40 heads) fit between the shock towers?
Thanks
jim
T
The Dan
319
Orange County, CA
Oct 13, 2006
  • Oct 13, 2006
Is the flange covering the exhaust port from the bottom, or sides? You may have headers desiged for heads with raised exhaust ports???
J
jim7485
64
Michigan
Oct 13, 2006
  • Oct 13, 2006
Now that's a great question. As I recall, the overlap was on the sides. If anyone else is using the crate motor with GT40 heads, which shorty headers are you using?
Thanks
jim
J
jim7485
64
Michigan
Oct 13, 2006
  • Oct 13, 2006
The correct answer
Here's the correct answer right from Hedman tech: Thank you for using Hedman Products. Part# 88400 is designed for a stock application. These hedders will choke the motor. So they will come off. I'll measure the clearance this weekend to see if the FMS hedders will fit between the shock towers. Obviously some cutting/welding on the H pipe will be in order too.
Thanks
jim
T
The Dan
319
Orange County, CA
Oct 13, 2006
#10
  • Oct 13, 2006
  • #10
Glad you got it figured out. Headers always seem to be a problem for people, myself included. Sometimes wonder if they're worth the problems....ya, I guess they are
Good luck.
valve guide question
  • 67rcks
  • Jun 26, 2008
Classic Mustang Specific Tech Jun 27, 2008
67rcks
Quick GT40P Header Q, will FMS Fit??
  • Chern_889
  • Nov 11, 2008
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Nov 12, 2008
grngt50
G
What heads studs do I need?
  • Black1987Stang
  • Jun 21, 2008
Fox 5.0 Mustang Tech Jul 13, 2008
Black1987Stang
E
Headers
  • escapethefate
  • Sep 13, 2007
2K
Classic Mustang Specific Tech Sep 19, 2007
fordkid
F
I
presure plate woes
  • iapexl8r
  • Jun 24, 2007
Classic Mustang Specific Tech Jun 24, 2007
iapexl8r
I
