Head Gasket leak/hissing noise
  • Thread starter Thread starter tommy_1812
  • Start date Start date Nov 26, 2006
T
tommy_1812
41
Kerrville, TX
Nov 26, 2006
  • Nov 26, 2006
Earlier today I got home and turned my stang off. I saw smoke coming from the hood, so I popped the hood and saw smoke coming from underneath the passenger side valve cover/head gasket area. I also heard a hissing noise coming from this area (sounded like pressure being relieved). I noticed a small amount of antifreeze on top of the passenger side "Ford Motorsport" valve cover. Head gasket leak perhaps?
I've checked the oil and it seems fine. It is running Royal Purple 20W50 oil. It's a 1990 5.0.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Nov 26, 2006
  • Nov 26, 2006
probably not a head gasket if its on top of the valve cover. do you have the coolant lines hooked up to the egr spacer? it could possibly be coming from there. or maybe the coolant pipe that runs along that side of the intake sprung a leak
T
tommy_1812
41
Kerrville, TX
Nov 26, 2006
  • Nov 26, 2006
I will check along side the intake coolant pipe to see if it leaked. What concerns me is the hissing noise coming from this area after turning off the car. It sounds like a radiator blowing off pressure.
There is also oil leaking from either the head gasket or the valve cover which is running down to the header causing smoke.
I don't know if the hissing is coming from the coolant pipe next to the manifold, or from the apparent gap in the valve cover or head gasket.
The engine runs fine, no known difference in the way it runs today and last week.
Mustang78
486
Aberdeen, WA
Nov 26, 2006
  • Nov 26, 2006
does it overheat? the hissing coulda been the radiator cap leaking a little..check the compression and cylinder leakage test to find out if it's a head gasket, there are some smarter guys here that would be of more help, hope its not a head gasket!!(but hey, if it is those heads needed porting anyway, right? haha)
~Mark~
TheBocSez
652
Converse, TX
Nov 26, 2006
  • Nov 26, 2006
I had a similar issue and it was the gasket at the EGR spacer. I never noticed the hissing noise, but then again, I never listened for it.
Makes sense, its part of the cooling system so it would be pressurized like the rest of it. So if its leaking coolant and the system has 16lbs of pressure, its gonna hiss a little.
Then again, could the hissing be the sound of the coolant hitting the header and burning off?
Either way, its does not sound like a head gasket issue.
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
Engine Stock TB - smoke test - leaking bad
  • R82148V
  • May 18, 2025
2K
Fox 5.0 Mustang Tech Jun 5, 2025
R82148V
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Q
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
