Head Gasket Problem ??????
  • Thread starter Thread starter af62cobra
  • Start date Start date Jun 20, 2011
A
af62cobra
  • Jun 20, 2011
engine ran hot and blew head gasket replaced both head gaskets while it was down. Now it's smoking getting oil in cly. If heads didn't seal can that cause this problem
BYRDPE
1,556
Memphis,Tn.
Jun 20, 2011
  • Jun 20, 2011
iron or aluminum...did you have the heads checked?
R
rrl
92
  • Jun 20, 2011
did you use new hardware?if you used old the threads are streched and you aren't getting the proper torque.also check the heads for warpage with a metal straight edge across and diagonally looking for air gaps.
A
af62cobra
  • Jun 20, 2011
heads are e7 i check to see if they were warped length but not across but didn't have them checked for cracks
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jun 20, 2011
  • Jun 20, 2011
If you live in South Florida I'm trying to give away the stock E7 heads.
Sounds lime they weren't seated properly. They heads need to be torqued down in three torque sequence and there is holy sequence to follow too. If all isn't done correctly you will have issues.
R
rrl
92
  • Jun 21, 2011
i'd also get a good quality gaskets such as felpro.
4rdnut
188
  • Jun 21, 2011
might be the intake manifold not sealing tight and sucking oil into a cylinder via a bad intake gasket port seal. if you are using printoseal gaskets there is a good chance its the intake.
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
