Head studs or bolts?
  • Thread starter Thread starter Lemonade
  • Start date Start date Sep 8, 2007
Lemonade
827
San Ramon,CA
Sep 8, 2007
  • Sep 8, 2007
I'm getting ready to start putting my top end back together, I was thinking of going studs. What are the pros or cons? BTW, I am running boost, 10lbs or so, a small shot of nitrous, TFS heads.
TIA,
Lems
twistedwankel
200
Spring Hill, FL
Sep 8, 2007
  • Sep 8, 2007
ARP studs are the way to go. Summit has them cheap for every application.
Be sure to note the "extreme" torque levels of the studs compared to the bolts. BTW they don't stretch either and can be reused. Get the metal head gaskets too. Worth the money and nothing will ever lift on you under boost.
Check with others on your specific valve covers to make sure they won't hit. Sometimes one has to gouge out a spot here or there due to the higher stud sticking up is all to get them to seat tight.
10psi....hmmmmmm....did you lower the compression at all? I'm conservative is all.
kbeefy
29
  • Sep 8, 2007
pro's are you get full engement in the head, much stronger than bolts. With the aformentioned head gaskets you'll get a more reliable combustion chamber seal.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 8, 2007
  • Sep 8, 2007
ARP bolts and ARP studs are very similar in strength.
However, Studs are the way to go with boost
Lemonade
827
San Ramon,CA
Sep 9, 2007
  • Sep 9, 2007
Clearance is what I'm afraid of, I'm running some pretty tall covers. Not so sure about gouging them out, they are carbon fiber. 9:1 compression, 42# injectors, fuel rails, AFPR, in tank fuel pump upgrade w/T-Rex, new water pump, alum rad, and a decent tune.
Lems
C
cjnecessary
70
richmond,in
Sep 9, 2007
  • Sep 9, 2007
I just studded my heads and had no clearance problems with the valve covers. I have a stock height v/c also. Hope that helps.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 9, 2007
  • Sep 9, 2007
WTF? Clearance problems with valve covers? I don't even see how that would be possable,your rockers would be smacking them first.
Lems,the studs are better as they engauge the threads in the block better,and also don't twist as much when being torque (there by "loosing" torque).Head studs DO stetch.Do NOT over tighten them by more than %20 percent MAX torque value (listed on box or data sheet) otherwise they will be streched to the point they will no longer hold propr torque.
Use the ARP moly lube,not 30wt oil for best results.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
Resolved Oil pan welds cracking
  • D & D Racing
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
revhead347
