Headlight Switch Repair Kit
  • Thread starter Thread starter Treachery
  • Start date Start date Mar 8, 2007
T
Treachery
148
Mar 8, 2007
  • Mar 8, 2007
My '93 headlights turn off shortly after turning on the foglights. I have found a "Headlight Switch Repair Kit" in 50resto.com which addresses the #15 ciruit overheating issue.
The kit includes:
1 - HEADLAMP SWITCH
1 - MULTI-FUNCTION SWITCH
1 - HEADLIGHT SWITCH CONNECTOR
1 - REPAIR HARNESS FOR MULTI-FUNCTION SWITCH
2 - TERMINAL CONNECTORS
My question: Is the replacing the multi-function switch really necessary? The kit sells for $200 because a new multi-function switch is included.
I've had my '93 GT since the beginning and only recently my headlights started flicking when the foglights are on.
wht87gt
127
Oxford, MA
Mar 8, 2007
  • Mar 8, 2007
Here's a link to a good write up on how to fix this problem.
http://www.corral.net/tech/maintenance/foglights.html
HISSIN50
34
129
Mar 8, 2007
  • Mar 8, 2007
You could do the fog light relay retrofit if you only have issues when the fogs are on.
I'm kind of a piece it together type of guy, so the benefits of a kit like that are lost on me. I'd also not have reason to think your MF switch is bad. A 2 dollar relay might be all you need.
Good luck.
Aryan15
236
CA
Mar 8, 2007
  • Mar 8, 2007
I agree, I just used a relay and it works fine.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 9, 2007
  • Mar 9, 2007
I had some smoke from my light switch one time when I had the lights and fogs on so I pulled the fuse for the fogs....I want to do this mod but havent got around to it
HISSIN50
34
129
Mar 9, 2007
  • Mar 9, 2007
Roland, when you do the retrofit, check the main wire feed from the headlight switch to the MF switch (it was red/yellow on my car, IIRC, and of decent size gauge compared to the other wire near it).
You might have begun to burn that wire up if the headlight's thermal breaker didnt kick in time.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Mar 9, 2007
  • Mar 9, 2007
The reason the multi-function switch is included in the kit is because a lot of stangers burn there's up by overheating it.
I put up with the whole fog-light flickers an headlight shuting off issues to the point where my multi-function switch took a total dump.
HOWEVER, if the ONLY time you have any headlight issues is when the fogs are on then your multi-function switch should be totally fine. you MAY have some melted plastic connectors back there.. but all the wiring should still be in order.
Just do the resto-mod Write that provided in the link above.. no need to drop 200 bucks on a 20 dollar fix (Like i had too... the multi-function cost me 120bucks from ford.. .but I also won exactly 120 bucks on a scratch off that day.. go figure )
tording
164
Hampton, VA
Mar 9, 2007
  • Mar 9, 2007
Use a relay and you will be fine. If it just started happening then I would bet your MF switch and your headlamp switch are fine. Just wire up a relay to keep that current out of the switch and you will be fine.
mustang302fan
Wichita, KS
Mar 9, 2007
  • Mar 9, 2007
i used the corral.net post that gives the part numbers and all and it was a simple fix. i performed this 5 years ago and never had a problem since.
T
Treachery
148
Mar 16, 2007
#10
  • Mar 16, 2007
  • #10
Thank you all.
I changed the relay and so far no problems. If the headlights go out again when the foglights are on, go with the info from corral.net which i have saved.
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
