Headlights Just off
  • Thread starter Thread starter dea7
  • Start date Start date Jun 7, 2004
D
dea7
Connecticut
Jun 7, 2004
  • Jun 7, 2004
Hi Guys!
I am new to this forum and have a concern with my 1988 5.0. On the way to work tonight, all of a sudden with my bright lights on my headlights just turned off. I then pull back on the lever and switch it to normal lights and it stayed on for about a mile or so. Then the lights shut off again! I pulled back on the lever and flicked the headlight switch and the lights came on again and then off. This continued all the way to work and then finally I held the lever back and drove in with the bright lights on.
Does anyone know what could cause this? In fact I parked my car and let it idle for about 5 minutes and turned the lights on normal and it stayed on by itself.
Help Please!
trbkrb
1,976
Houston, TX
Jun 7, 2004
  • Jun 7, 2004
Common problem. That is the headlight circuit breaker tripping before the wires melt and catch on fire! The Ford lights are wired badly, running the entire current through the switch, instead of using a relay to power the lights. There is an article with instructions on how to rewire it, but I can't seem to find it. Maybe someone else can post it up. Last time I pulled my light switch fron the harness, I noticed the wire plug was slightly deformed and brown, so I probably need to fix it also.
BrettSanders
15
USMC
Jun 7, 2004
  • Jun 7, 2004
I wouldnt recommend holding the lever back and forcing them on for much longer- the breaker is doing its job
HISSIN50
34
129
Jun 7, 2004
  • Jun 7, 2004
yep. i would personally stick a SPDT relay on the lows at a minimum. i like excess, so my lows, highs and fogs (GT) are all on relays.
welcome to the boards. good luck.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Jun 7, 2004
  • Jun 7, 2004
relays are a bitch
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 7, 2004
  • Jun 7, 2004
See http://www.corral.net/tech/maintenance/foglights.html for the fix...
J
Electrical problem with headlights
  • jeremykrell308
  • Oct 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2025
General karthief
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
