Hello
  • Thread starter Thread starter Otto1970
  • Start date Start date Nov 24, 2007
Otto1970
28
South Florida
Nov 24, 2007
  • Nov 24, 2007
Hello folks, Joe newbie here. This is my first time posting and would like to know about the unwritten rules of etiquette on how to utilize this impressive knowledge base (the do's & don'ts). I have a 1992 LX notch that is currently torn apart in my shop awaiting the following upgrades which have already been purchased: 5-Lug Front/Rear Super Heavy-Duty '' Cobra '' Disc Brake Conversion Kit, Tremec TKO 500, King Cobra clutch kit, AJE Mustang Tubular Front K-Member, Steeda Stage 3 suspension and battery relocation kit. The plan is to represent the 5.0L universe well on a daily basis in a land where foreign mega-buck sedans, sports cars and SUV's reign supreme (Naples, FL.). My plans for power include a 331 crate w/ Cobra or GT-40 induction.
ttop88
42
indiana
Nov 24, 2007
  • Nov 24, 2007
Hello and welcome. As for etiquette You could start by posting this in the talk section. You you need help installing said parts that is a differant story tho.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 24, 2007
  • Nov 24, 2007
Welcome to the board Otto. That's a sound game plan you've got there. The first rule of etiquette on this board is to keep the Talk posts (like this one) it Talk and the Tech posts in Tech.
...otherwise, you're doing well.
Otto1970
28
South Florida
Nov 24, 2007
  • Nov 24, 2007
Thanks guys.
FrankenStang
Now, give me a damn CT!
4,461
70
129
Florence, Az
Nov 24, 2007
  • Nov 24, 2007
The Written Rules of Stangnet Ettiquette.
http://forums.stangnet.com/showthread.php?t=667861
Welcome and post pics of said Notch plz kthxbyeeee.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 25, 2007
  • Nov 25, 2007
Welcome to Stangnet...
Not all of us know how to fix everything, but some of us know how to fix some things with excellence!
If you want to do the fix up & power up thing, make sure that you have some other form of reliable daily driver. That way the stang can sit while your wallet and hands take a rest from the last project that didn't quite get finished on that 3 day weekend. Things always cost more and take longer the first time you do them. Having some other working vehicle makes life easier since it isn't the big crush to get it running for the Monday morning drive to work or class.
Plan on spending some money on tools it you don't already have them. The stang has both metric and american fasteners, so you really need two sets of wrenches. A timing light, digital voltmeter, vacuum gauge, compression tester, fuel pressure test gauge and fuel line coupler tools are some of the test & tuning tools you'll need. Visit the pawn shops and sometimes you can find a deal on tools & test equipment if you stick to well known name brands.
A sheltered work area is almost a must, someplace that you can leave the car in pieces without upsetting anyone. Some guys here have changed a transmission in the parking lot of their apartment in a rainstorm, but they will tell you it wasn't fun. Depending on where you live, a warm dry garage is a nice place to do the winter projects that stangs tend to become.
EFI (Electronic Fuel Injection) Computer - every stang after 85 has or had one: don't let it intimidate you. The computer based EFI systems are not hard to fix and most of the time they tell you what's wrong with the engine. Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst :ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo....php?t=643651"]Useful Technical Thread Index at the top of the 5.0 Tech forum for lots of good tech notes on upgrades and fixes.[/b]
Things that break often:
T5 5 speed manual transmission (syncros go bad, mostly 3rd gear)
TFI Module (Thin Film Ignition module - mounts on the distributor)
Electric door locks (see the link in my sign for a cheap & easy fix)
O2 sensors(oxygen sensors) They are good for about 60,000 miles and start to go down hill after that.
TPS Sensor (Throttle Position Sensor) causes flaky problems with idle & acceleration.
Fog lights They overheat the wiring and cause the headlights to flicker. The fix is cheap and simple if you can do electrical stuff.
Harmonic Balancer – they separate between the hub and outer ring. A harmonic balancer puller is a must have to change it. You can rent or borrow a puller from most of the larger auto parts stores.
Things that are very durable:
Engine - as long as it hasn't been abused, it will run good for 150,000-200,000 miles without an overhaul
Rear axle other than an occasional case of worn clutches in the traction lock, they almost never have problems.
Computer - believe it or not, the computers seldom have problems of their own. Most of the problems are with the sensors and the wiring.
Suspension – the front and rear suspension has very few problems if the car hasn’t been wrecked or seen a lot of drag strip runs. The drag strip runs tend to distort and tear the mount points for the rear axle control arms. Revving the engine up to 4000 RPM and dumping the clutch with slicks or drag radials tends to break things.
Things that don’t break often but are hard to fix:
Water pump mount bolts – they corrode and shear off when you try to change the water pump.
Rear oil seal on the engine – lots of parts to remove to get to a $20 seal.
Power steering pump – the pumps are noisy and the pulley requires some special tools to remove and install. If you have the tools, they are easy to do. Again, the larger auto parts stores will rent or loan the tools for the pulley.
Power Steering rack - it is hard to get the toe in set so that you can drive the car to the shop to get it properly aligned.
Starter – the top bolt is hard to get a socket on if you don’t have the right combination of socket, universal joint and extensions.
Everything considered, 5.0 Mustangs are not hard to work on. They just require some patience and though before you get started.
For lots of great ideas and tech notes on upgrades and repairs, be sure to check out the “Useful Technical Thread Index” sticky at the top of the 5.0 Tech forum.
Otto1970
28
South Florida
Nov 25, 2007
  • Nov 25, 2007
Thank you.
Wow... thanks jrichker for the overview on whats to come and how to go about getting it done.
Flavadave4
1,044
21
49
Utica, NY
Nov 25, 2007
  • Nov 25, 2007
Welcome aboard!
Visit the sticky's at the top of the sub-forums, they are usually areas that have been coverd and have tons of good info.
Learn to use the search feature and get a basic knowledge of things on your own, nobody here has everything figured out so grabbing bits and pieces here and there is the way to go. They you can ask good questions.
Happy Stanging
  • Locked
Expired 94gt Bolt Ons Nj $1000
  • 95PGTTech
  • Dec 19, 2013
11K
SN95 Mustangs For Sale (1994-04) Dec 19, 2013
95PGTTech
9
  • Locked
FS: 1993 LX 5.0 347 stroker reef blue/black int.
  • 87nitemare
  • Mar 9, 2010
19K
Fox Body Mustangs For Sale (1979-93) May 19, 2010
87nitemare
