  • SN95 4.6L Mustang Tech
help before installation?
  • Thread starter Thread starter eleanor'03
  • Start date Start date Dec 15, 2004
E
eleanor'03
117
  • Dec 15, 2004
i'm going to install the eibach sportlines tomorrow. i have two websites dedicated to the installation. does anyone whose done the installation have nething to say about it. trouble you had and things you did to overcome it? or is it pretty straight forward? also i got the c/c plates, how long before alignment?
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 16, 2004
  • Dec 16, 2004
it's straight forward. just make sure you got the right tools, 2 jacks, stands, spring compressors. and get an alignment right after your done.
Blue70
160
28
38
Wilmington NC
Dec 16, 2004
  • Dec 16, 2004
I just did mine a week ago, took an hour to do all 4.
I used 1 jack and a pair of jack stands, and no spring compressor, but I did have an electric impact to speed things up.
I did throw a small chain through the spring and A-arm pivot point just in case the spring wanted to say hello to me, but they were never needed.
I was told to drive it a week before aligning it so the springs can settle a bit, but if you are doing CC plates at the same time there is no way you can be close when you are done, so I would do it ASAP because it can really mess with your cars handeling and tire wear.
I followed the instructions here
Click here for spring install instructions
There are a couple things with those instructions.
1. You need to undo the front swaybar on whatever side it is you are working on. They show it in the picture, but don't list it as a step in the instructions.
2. At the top of the strut you only need to undo the large center bolt, not all three bolts as shown. (If you have a hard time with the nut at the top you could also undo the two nuts at the bottom of the strut.)
OOPS If you have new CC plates you will have to undo the 3 at the top of the strut.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 16, 2004
  • Dec 16, 2004
Great info Blue!
thanks
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • dan50
  • Jul 18, 2026
dan50
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
