  • SN95 4.6L Mustang Tech
help? car running sluggish.
  • Thread starter Thread starter sicK96GT
  • Start date Start date Nov 13, 2006
sicK96GT
63
Austin (College in Waco)
Nov 13, 2006
  • Nov 13, 2006
Had some problems with the radiator (nice big crack in the plastic after running something over on I35) It was replaced, but because of it the intake manifold cracked (running too hot, damn plastic) The car was running sluggish because of it and I could hear what sounded like a lot of air being pulled in (like a vacuum leak) I figured it was the intake and decieded to replace it and upgrade to a PI intake as well.
While doing this i also bought new PCV, Intake flow sensor, fuel pressure regulator, and EGR valve. I cleaned out the IAC and looked for any vacuum leaks. I put all new seals on the injectors (they looked clean).
The car is still running sluggish and still sounds like air is blowing. By sluggish I mean under 3000rpm seems like not enough gas it getting through but after 3-4000rpm it kicks in and runs okay. The only thing I can think of that I have not tried is replacing plugs and wire as I have already replaced the sparkplugs less than a month ago. OR a bad vacuum leak that I cant seem to find.
If it was a fuel pump the car wouldnt start. The fuel filter was replaced a month or so ago.
any ideas?
basicly, I spend $300+ for something that didnt really fix my problem.
sicK96GT
63
Nov 13, 2006
  • Nov 13, 2006
turned out to be a vacuum not hooked up under the throttlebody (next to the intake flow sensor), thats what seemed to be leaking dont know what was hooked up to it yet but i plugged it. Runs pretty now.
sucks because i had the throttlebody off and on the ground and never even looked at it to see that penny size hole in it.
H What 4.6
56
  • Nov 13, 2006
glad to see you figured it out with all the help we gave you
sicK96GT
63
Nov 13, 2006
  • Nov 13, 2006
its all good, I had a nice long day with the stang, just missed all my classes searching for the problem, scared the **** out of me when the vacuum sucked my finger up.
P
pkpab
New Jersey
Apr 9, 2009
  • Apr 9, 2009
Had a 97 gt and the intake manifold cracked, when i replaced it, car still was running sluggish...the cats turned out to be the problem...when i put new ones car ran fast....now im having the same problem with my 96 gt, Im thinking of cutting the cats and running straight pipes
jayrw
156
Clovis, California.
Apr 10, 2009
  • Apr 10, 2009
Quick question on cats, If I can smell a "egg" type smell when I get on the throttle hard is that a possible cat issue?
StangYellow
1,052
Apr 10, 2009
  • Apr 10, 2009
Sounded like you had a sick96GT
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
