help on exhaust!!!!!!!
If you have not already converted over to dual exhaust you will need a double hump crossmember and the x or h pipe of your choice to make it work. Do a search and you'll find hundreds of threads on exhaust preferences.
i can't see why it won't. As long as the engine sits in the same location so that the h-pipe fits to the headers at the same angle and the suspension in the rear doesn't interfere with the axle over's. it should work.
