  • SN95 4.6L Mustang Tech
HELP PLEASE!
  • Thread starter Thread starter Origommi
  • Start date Start date Aug 29, 2004
O
Origommi
180
  • Aug 29, 2004
I know this has happened to a few of you so any advise would be appreciated. My 96 GT will start, but wont stay running unless the I press on the gas pedal. As soon as I let off it dies. I was thinking maybe fuel filter, PCV valve or something along those lines. Thanks guys.
madmatt
Ellis Juan sympathizer
465
Lexington, SC
Aug 29, 2004
  • Aug 29, 2004
Sounds like the IAC is acting up. Clean it and see if that helps the problem with some carb cleaner. If that helps, just go ahead and buy yourself a new one so that you dont have to deal with it again.
Try here: http://www.muscularmustangs.com/iac.html should give you a better idea of what to do.
white99gt
4,649
stockbridge,Ga(near atlanta)
Aug 29, 2004
  • Aug 29, 2004
I agree with matt.The IAC has gone bad.Best bet is just replace it..Cleaning may help it but its gonna come back ...
O
Origommi
180
  • Aug 29, 2004
Hmmm
I drenched the dang thing in Carb Cleaner and it seems to be running fine now, BUT now the check engine light is on. Do we all still think its the IAC? And if it is any idea on how much they are going for?
white99gt
4,649
Aug 29, 2004
  • Aug 29, 2004
Light could be on because you may have unplugged it with the key on?
Just take it to autozone or somewhere and have them check the code ..
I think they are around 50.00 ~75.00 ..
O
Origommi
180
  • Aug 29, 2004
Can anyone tell me or have a pic of where the IAC is on a 96 GT. I heard that once you find it, it only takes 5 minutes to replace.
O
Origommi
180
  • Aug 29, 2004
And..... will it run if you disconnect it?
J
jbrown
393
Tallahassee, FL
Aug 30, 2004
  • Aug 30, 2004
how did you drench the thing in carb cleaner if you cant find it? on my 99 its attached to the upper intake plenum, right on the front of it, it has one wire running into it and one hose. Do a search on here if you cant find it there was a pic posted with it labeled. Definately sounds like a bad iac I found one at napa for 51.99 autozone didnt keep them in stock, discount didnt sell it.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 30, 2004
  • Aug 30, 2004
Well if it won't run clogged up it definatly won't run if you disconnect it.
It is attached to the front of the TB...there is a thread with a pic here somewhere but since we can't search anymore I guess you will have to guess.
EDIT: Found one...
http://forums.modulardepot.com/attachment.php?s=&postid=250840
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
