  • 1994 - 1995 Specific Tech
Help Please
  • Thread starter Thread starter zratedmustang
  • Start date Start date Nov 19, 2004
Z
zratedmustang
12
  • Nov 19, 2004
My car died on me the day before yesturday while driving to work. At first I thought it was the fuel pump due to there being no fuel pressure, however I checked for power first before having to remove the tank and I found none. A friend of mine told me it might be the Constant Control Relay Module which is located next to the coolant reservoir. I did a back probe test on the harrness and there was no power coming out so I went and bought it. After installing it my car still does not turn on, or the fuel pump. I bypassed the relay module and it turns on the fuel pump so did I get a bad module or is there something else I should be looking for?
M
mo130
las vegas
Nov 19, 2004
  • Nov 19, 2004
Did you check the inertia switch (ifs)? Sometimes hitting a bump just right can actually trip it. Its located in the trunk.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 19, 2004
  • Nov 19, 2004
Sound like the inertia switch like mentioned. It's on the left hand side near the tail light press the switch and see if she turns on.
Z
zratedmustang
12
  • Nov 22, 2004
Thanks, I did check the inertia switch, however it was the CCRM. Apparantly when the old one went out it also shorted out a fuse. Car is now running fine.
gcomfx.com
3,690
Republic, MO
Nov 22, 2004
  • Nov 22, 2004
Good to hear it's fixed.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
