  • 2.3L (N/A & Turbo) Tech
HELP!!!!!!!! PLEASE!!!!!!!
  • Thread starter Thread starter philster
  • Start date Start date Jul 7, 2006
P
philster
dfw, texas
Jul 7, 2006
  • Jul 7, 2006
ok, one thing bad after another. im working on a friend's '85.5 svo. all stock.
1st, the initial problem w/ the car was that around when it spools it starts to cut out and stops making power through the rpms. kinda like its missing but not. seems like the fuel cuts off but when driving normal its fine....out of timing maybe?????
2ND!, i drove it around the block and i opened it up in 1st to show a friend wat it was doing and about 5 grand it backfired horribly loud and then it died. as i was rolling i put it in 2nd and popped the clutch to start it and it wouldnt start. after i can to a stop i tried to start it and it wouldnt start. it turns over fine it just wont start.
HELP WOULD BE AWESOME!!!!!! ASAP!!!!
thanks
Dr_EluSivE
2,155
Central Illinois
Jul 7, 2006
  • Jul 7, 2006
sounds like the timing was/is way off, Check the timing belt, make sure its lined up like it should be. I would also have the TFI module tested. Does the car have decent fuel pressure?
K
kevinspann
Richmond, VA
Jul 7, 2006
  • Jul 7, 2006
It sounds like the timing was the problem, but if it backfired but wouldnt start again, then you may have fried something
P
philster
dfw, texas
Jul 7, 2006
  • Jul 7, 2006
ill check the timing and everything, but whats is a TFI module/its location?? (i normally work on hondas/acuras so some of this is new) but im not sure how the fuel pressure is. i only had the car for about an hour 1/2 before it pulled this.
BELL
722
California
Jul 7, 2006
  • Jul 7, 2006
sounds like you jumped time. check the timming belt tensioner make sure it still has some tension left in it. reset base timming and try again. oh why your in there change the belt too.
fuel pressure should be around 40psi
TFI module is located on the back side of the dist. toward the firewall.
P
philster
dfw, texas
Jul 7, 2006
  • Jul 7, 2006
i took the dizzy cap off and the metal piece on the rotor was broke off and it was like, burned up. so i bought a new rotor and still doesnt start. seems like theres not any spark. but the owner told me that he took it to a shop and an hour later the dizzy and the coil ****ed up. possibilties that would have happened for some odd reason again?
question. which way on the dizzy is advanced/retarded? clockwise/counter clockwise?
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jul 7, 2006
  • Jul 7, 2006
counter clockwise: advances
clockwise: retards
josh
P
philster
dfw, texas
Jul 7, 2006
  • Jul 7, 2006
ok FOUND THE PROBLEM....just dont know what could cause it.
OK.....well, we pulled the dizzy out and the gear thats at the bottom was "partially broke", as my friend put it, and it was missing a couple teeth. wat the hell could cause that???
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Jul 10, 2006
  • Jul 10, 2006
the gears overtime get play in them and in turn makes them rip the teeth off of each other, I went through two dist gears and a imput shaft in one week, it happens.
Josh
Brantley
1,329
Memphis, TN
Jul 10, 2006
#10
  • Jul 10, 2006
  • #10
Sounds to me like potentially an oil pump problem. Likely a clogged pickup screen. Do you have access to a real oil pressure gauge? If so, hook that up and see what's going on with your pressure.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
