  • SN95 4.6L Mustang Tech
HELP! Stalling Out
  • Thread starter Thread starter roman
  • Start date Start date Apr 19, 2006
R
roman
49
marshall,mo
Apr 19, 2006
  • Apr 19, 2006
Okay guys I have a problem! Over the weekend I was taking a 2 and a half hour road trip and my mustang stalled out on me 4 different times. The first time like every other time, I was cruisin about 70 at around 2.2K rpms and my car just looses all power so I push in the clutch and the engine drops to about 1K rpms, stumbles, and dies. So I pull off to the side and I will not start at all, so I wait about 5 min. and try it again and it starts then dies again. Then after waiting about 15 min. it fires up and drives normal for about 10 minutes and the whole process startes all over again. It repeated 3 different times. The temperature is running normal, and there isnt any "check engine" lights on or anything.......Im lost! Do you all have any opinions???????
Thanks
R
Red2000GT
2,450
Regina,Sask.Canada
Apr 20, 2006
  • Apr 20, 2006
Sounds like a vapor lock problem which was common on the fox bodies but not so much on the fox-4 and newer. I'd be really suspicious that your fuel pump is on it's way out.(not pumping enough fuel through the lines to keep it circulating making it overheat and vaporize in the lines in the engine compartment)
the98stang
2,408
Clovis, CA
Apr 20, 2006
  • Apr 20, 2006
Check all the vaccum lines first. There could be some sh1t getting caught in the injectors/pump from the gas. You can test the fuel pump and make sure it's functioning properly. That's my 2 cents.
R
roman
49
marshall,mo
Apr 29, 2006
  • Apr 29, 2006
Ive checked all of my vaccum line, and they all seem to be okay. I dont really have a solid way to check out my fuel pump because it it only acts up occassionaly....but I am leaning towards the fuel system! IS there any more ideas???????
thanks
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 29, 2006
  • Apr 29, 2006
In my opinion it is def fuel related. How many miles on your fuel filter? Do you use whatever gas or top tier gas?
Dorsai
Connecticut
Apr 29, 2006
  • Apr 29, 2006
Ignition problem. If it was fuel related you'd notice it while accelerating. If the fuel pump is not noisy and you kept up on fuel filters then I'd guess you have an ignition module crapping out or some other ignition related problem. Have you had the codes pulled ?
R
roman
49
marshall,mo
Apr 29, 2006
  • Apr 29, 2006
I whatever gas is cheapest, I usually run 89-93 octane. My car has around 90k miles on it and Im pretty sure its still runnin the stock filter. I forgot to say that when Im crusin around town it runs just fine, just every now and then it f**ks up on the highway.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Apr 29, 2006
  • Apr 29, 2006
Start with the cheap options first...fuel filter, maybe some additive that removes moisture.
tomustang
Psychotic Member
3,434
McLean Hospital
Apr 29, 2006
  • Apr 29, 2006
Could be an alternator/battery problem
R
roman
49
marshall,mo
Apr 29, 2006
#10
  • Apr 29, 2006
  • #10
I just got finished changing my spark plugs, they was in pretty bad shape! I plan on changing my fuel filter tomorrow.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
