- Apr 14, 2004
- 15
- 0
- 0
Hey guys, I've been chasing this problem for about 2 weeks now and still no luck. First off the problem.
When I go start the car the car barely cranks once and stops. Sometimes it has enough to start the car barely. I have charged the battery and tried it. The first time I turn the key it does the samething (Barely cranks over oncce and stops). Then the second time it will start up with little trouble. This happens even after a long drive and whatnot even with a charged battery.
Things I have done:
New battery, New ground in the back where the battery is, New solenoid, then a whole new starter with another solenoid, got the alternator check and checked out fine. I have followed wires everywhere and can't find anything wrong.
Is there any test I can run to pin point the problem and finally solve my problem. Voltage regulator not charging the battery? But that has nothing to do with the starter when I go start it. How can I test the wires going to the starter? I dunno, i'm about to torch this thing. Any suggestions will help. Thanks Guys
Things I have done:
