HELP WITH 8.8" REAR END GEAR PATTERN
LT1LE
How does the gear pattern look?
PINION SETUP:
PINION HEAD 1.886" SHIM 0.015"
PINION DEPTH 4.420"
4.420" - 1.886" (FORD RACING PINION HEAD) = 2.534"
3.100" - 0.566" = 2.534"
This is the tool i used:
http://static.summitracing.com/global/images/instructions/pinion setting tool combined atech.pdf
BACK LASH SETUP:
DS: 0.259" + 0.012" = 0.271"
PS: 0.100" + 0.100" + 0.020" + 0.020" + 0.020" = 0.260"
TOTAL BACK LASH 0.009"
Drive side:
Coast side:
+.005" On pinion shim.
How does it look now?
Drive side .015" SHIM / BACK LASH .009":
Drive side .020" SHIM / BACK LASH .007":
Coast side .015" SHIM / BACK LASH .009":
Coast side .020" SHIM / BACK LASH .007":
To me the 0.020" shim looks pretty good. I'd guess that if the backlash is right and the preloads are right you shouldn't get any noise with that.
I'd wait for one or two more opinions to be sure though :D
