i just recently finished my 4cyl conversion.
drove the car from my shop to the alignment shop(about 1.2 miles) and left it over night.When i went to pick it up after work the next day, i started it, let the idle settle and made it to the edge of the parking lot and it died. I pushed it back into a spot and started checking things...
no fuel pressure. relay was clicking but the pump didnt always prme, but if i cycled it a few times it would prime and would start but as soon as the idle came down it would die. towed it back to my shop
figured the 255 pump i got new off ebay must be junk. so i over nighted a new pump from the local speed shop this time. threw in the new pump and it fired right up. drove it about 8 miles total( a couple short trips) and it did the same thing at a stop light...towed it back again.
put a new relay in, thinking maybe it had a weak field once it had been on for a while....fired right up. drove it around(close to home this time) until it died(about 8 miles again), left it there came back 6 hrs later and it started, got it home and it died in front of my house.
checked all the wiring...12v all the way to pump connector, good grounds.
now its dead in front of my house, with a full tank. no tools at home.
i dont think its eating pumps, im thinking there's a bad connection(power or ground) some where in the pump module it self...
any opinions?
on a side note. how structurally important it the floor pan right above the pump? (if it was welded back together after the fact)
any opinions?
