Help With GT40 heads
  • Thread starter Thread starter TorchRed_4.0
  • Start date Start date Sep 26, 2021
TorchRed_4.0
67
Georgia
Sep 26, 2021
  • Sep 26, 2021
I have a set of GT40 heads and recently purchased an E303 cam to go with them.
My question is will those pair together and if so what all do I need to make them work together such as pushrods, springs, etc.
Mustang5L5
Mod Dude
Feb 18, 2001
43,298
18,003
224
Massachusetts
Sep 26, 2021
  • Sep 26, 2021
It’s a combo that’s been done plenty of times.
I’d recommend a spring kit from Alex parts
FORD, SMALL BLOCK 302 HO w/ E7, GT40P & GT40 - Alex's Parts Sales
www.alexsparts.com
You’ll need to measure the pushrod lenght, and I would stick with the factory 1.6 rockers. You can spend the cash on some aftermarket 1.6s but I don’t think your $$$ spent will be worth it here .
Reactions: RaggedGT
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,501
2,922
173
Florida
Sep 27, 2021
  • Sep 27, 2021
TorchRed_4.0
67
Georgia
Sep 27, 2021
  • Sep 27, 2021
www.alexsparts.com
I take it the stock GT40 springs can’t handle that e303?
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Sep 27, 2021
  • Sep 27, 2021
I do not know about all GT40 heads, but the gt40p heads’s stock springs are limited with the stock E7 5.0 cam.
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
Sep 27, 2021
  • Sep 27, 2021
Most of the time no unless they have been upgraded. You can always check coil bind, but Alex kit is cheap assurance you won’t float and smack a valve
Mustang5L5
Mod Dude
Feb 18, 2001
43,298
18,003
224
Massachusetts
Sep 27, 2021
  • Sep 27, 2021
Except that they are out of stock and have been for a while.
You may have to call and ask them to scrouge a kit up for you.
Trick flow makes a kit as well but tbh I like the Alex parts kit better for some reason
TorchRed_4.0
67
Georgia
Sep 28, 2021
  • Sep 28, 2021
Could you give me a link to some springs? I don’t want to buy the wrong ones, I just need some springs that go on the GT40 explorer heads that will work with the e303 cam.
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Sep 28, 2021
  • Sep 28, 2021
Buddy of mine ran a E cam on stock E7s for years with stock springs. Engine ran great. No float at all. Now we did try a set of 1.7RRs on it for the heck of it and that was a no go! Floated bad over 4500 RPMs.
TorchRed_4.0
67
Georgia
Sep 28, 2021
#10
  • Sep 28, 2021
  • #10
I’m not trying to be cheap, but if I can save $200 that would be awesome. Do you think I can get away with stock springs and the E303 or should I just go ahead and upgrade springs?
7991LXnSHO
7,387
2,745
194
Kearney, NE
Sep 29, 2021
#11
  • Sep 29, 2021
  • #11
Get matching springs so you do not have to wait for float or for it to drop a valve.
General karthief
Mod Dude
Aug 25, 2016
28,013
10,637
213
polk county florida
Sep 29, 2021
#12
  • Sep 29, 2021
  • #12
Say you save $200 by not replacing the springs, you're out cruising and hit the 'happy peddle' and miss a shift, valve float for a millisecond and kicks a retainer out or breaks a valve stem, BAMN!! You just threw that $200 out the window along with several more hunnert dalla bills.
Or it could run along just fine schlepping over to the cars and coffee on Saturdays.
I like a 'awh ' cushion. Do the valve springs.
DISCLAIMER: this is an opinion and not based on any real mechanical experience.
Reactions: Boostedpimp
Mustang5L5
Mod Dude
Feb 18, 2001
43,298
18,003
224
Massachusetts
Sep 29, 2021
#13
  • Sep 29, 2021
  • #13
The source of your GT40 heads should be taken into consideration. Are they early '96 heads off an explorer? Then you want to change the springs. E7 springs would be an upgrade over the stock truck springs. Are they off a 93-95 Cobra? They might be fine. No idea where they came from? Change them for piece of mind.
Dan02gt
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Oct 1, 2021
#14
  • Oct 1, 2021
  • #14
If you can find springs for $200 or less I would do it. Better to be safe.
R
Rcdgl
5 Year Member
Feb 19, 2018
313
168
63
Oct 2, 2021
#15
  • Oct 2, 2021
  • #15
Absolutely need to upgrade the valve springs. I used Comp Cams stuff on both sets. The set on my 82 worked perfectly with a stock (flat tappet) cam and stock pushrods with the orig bolt down rockers. Good to 6200 anytime. Need to check carefully, I needed different height retainers for intake and exhaust. Comp has them.
R
New heads
  • Robman8028
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2025
gkomo
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
