  • 1994 - 1995 Specific Tech
help with hew car!
  • Thread starter Thread starter deadlast
  • Start date Start date Sep 7, 2005
deadlast
495
Belmont, MA
Sep 7, 2005
  • Sep 7, 2005
well, i just got a new car, after my other got totaled. it was running great until i changed plug wires and installed a cai. turns out i had two wires in the wrong spot, but i fixed that and disconnected my battery to reset the comp. so it ran fine, drove it around maybe 20 minutes. then on my way home im sitting in traffic, and it just dies. i start it up, drive some more and it dies again. i bring it home, let it cool for 10 min with the hood up, start her again, and watch the engine while it idles for a minute or two. let it coll for another 10 minutes, and let it idle again for a minute or two. it will idles good for about 20 sec at ~800 rpm, but then drops to ~550 and stays there. it idles bearly enough to keep the engine going. whats going on?
Chin
39
Naperville
Sep 7, 2005
  • Sep 7, 2005
i idle about 550-600 all the time (stock)
i know it usually idles just a bit higher just after start up that might just be it?
HISSIN50
34
129
Sep 7, 2005
  • Sep 7, 2005
Any codes? Good luck.
deadlast
495
Belmont, MA
Sep 7, 2005
  • Sep 7, 2005
no codes, i ran it all evening and had no trouble. had it parked for a while, smelled like something burning from my car. not very noticable, but what causes the burning of oil?
BPA
159
S.F.
Sep 8, 2005
  • Sep 8, 2005
I would check the basics like your timing , making sure ur maf is clean, vacume leaks , fuel pressure and spark, and go from there
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 8, 2005
  • Sep 8, 2005
Ditto that. check your plugs/wires/cap/rotor while you are doing your testing/cleaning. The contacts on your rotor/cap are probably black if you haven't replaced them in a while.
Scott
deadlast
495
Belmont, MA
Sep 8, 2005
  • Sep 8, 2005
how can i check for vacume leaks or fuel pressure. im still slightly worried about the slight smell that is present when the car if off after it has been running a while. what can cause oil burning?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 8, 2005
  • Sep 8, 2005
Check vacuum with a vacuum gauge. Check fuel pressure with a fuel pressure gauge.
Are you sure what you are smelling is oil and not fuel???? Do you have any oil leaks at the valve covers or intake/timing cover?
Scott
94-302-vert
1,947
NE CT
Sep 8, 2005
  • Sep 8, 2005
you installed a CAI.. i would say to check all of the hose clamps.. if there is a leak bfore the TB but after the MAF the car will run like crap...
PRobably clean the MAF at the same time. The CAI filter could have been over-oiled from the factory...
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
