help with vss!
  • Thread starter Thread starter knuckl-head
  • Start date Start date May 4, 2007
knuckl-head
Clyde Ohio
May 4, 2007
  • May 4, 2007
I have A 1965 mustang with a 1991 efi 302 and aod. And my car is stalling at low rpm and when stoping.But the person I bought the car from never wired in the vss or even installed a speedo and cable.I need to know how to wire up the vss to the ecu.Any help would great!
88mouse
630
Mooresville nc
May 4, 2007
  • May 4, 2007
shouldn't really need one. People put C4 in and they don't have vss.
knuckl-head
Clyde Ohio
May 4, 2007
  • May 4, 2007
well I thought so to but it will sit and idle all day long but soon as I drive down the road and stop or slow down it will stall out.
tb9050lx
155
ct
May 4, 2007
  • May 4, 2007
def need a vss signal the pcm uses this signal to keep idle speed up when coming to a stop and to prevent stalling .iff its a factory harness it should have a connector for the vss ,look on the tranny also the vss should be installed unless the hole is plugged or u would have a major leak it should be on the drivers side towards the rear in the tailshaft housing.
A
ARTTII
272
Detroit, MI
May 4, 2007
  • May 4, 2007
What rpm is your idle set at? What code is on your computer?
D
Daggar
3,902
  • May 5, 2007
VSS is not your problem unless (possibly), you're running a computer from a 94+ (and even that's questionable). I run an A9L with no VSS. That signal input wasn't used by the EEC for "stop-stalling" until vehicles later than the Fox.
Your stalling problem is the result of something else that's not working or set properly.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 5, 2007
  • May 5, 2007
The VSS wasn't used by the computer until they went to Mass Air. On Mass Air cars, it does provide a signal to increase IAB airflow as the car slows to a stop. This helps prevent stalling, particularly with AOD equipped cars. I have watched the idle speed slowly drop after coming to a stop.
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=698148
for help with your idle problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions. The fix for your stalling problem will be in there.
knuckl-head
Clyde Ohio
May 5, 2007
  • May 5, 2007
thanks for all the replys. I have used the check list and fixed my idle problem.it was very helpfull.when i bought the car it would not even start or run.so hats off to you for your check list!far as i known the computer and harness is out of a 1991 5.0 stang.the computer is A9P.I have put a new iac,tps,plugs,cap and rotor on.i have pulled the codes and fixed what was on there then erased them.i have not checked them again have not had the time to.the car will stall out at a 1000 rpm or lower.it is like you cut the ignition off.i checked the msd box and wiring everything was ok.the car runs to good down the road to have a ignition problem.the guy who wired the car cut out any wires he did not want to use.so little by little i check and move on.i just thought that this was a good place to start.thanks once again!
  • Mindseye007
  • Aug 16, 2026
Mindseye007
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
