Help!!!
  • Thread starter Thread starter 808Gt
  • Start date Start date Jan 1, 2006
808Gt
115
Hawaii
Jan 1, 2006
  • Jan 1, 2006
Last night after work I went to put gas, then when i turned the ignition of, well I thought i did, I let the clutch out and the car was still running.... I was like WTF
Then i plaed around with the ignition lock and it was loose, like i could put the key in and literaly turn the key fron ACC-off-on.....
Im thinking that I have to replace the lock cylinder, I jus want to make sure it is the lock cylinder??
HISSIN50
34
129
Jan 1, 2006
  • Jan 1, 2006
It sounds like it to me. In any case, it sounds like you need a new lock cylinder, so even if that was not the issue, it wont be a waste. You can turn the car off, right? You just have to wiggle the cylinder to make it shut off (like the positions in the switch are kinda off), right?
Good luck.
808Gt
115
Hawaii
Jan 1, 2006
  • Jan 1, 2006
Nope ..... It is stuck on the on position and cant turn if off, I have to take out the batt. cable..... But Im gonna change the lock cylinder, is it hard to do??
HISSIN50
34
129
Jan 1, 2006
  • Jan 1, 2006
Well that sucks. The good thing is that it is stuck in the run position. Disconnect the battery. Then with it in the run position, there is a little button under the cylinder that you press and the cylinder slides right out. Install the new one the same way.
Good luck.
808Gt
115
Hawaii
Jan 1, 2006
  • Jan 1, 2006
cool thanks for ur help HISSIN50....... I knew it was the lock cylinder, jus needed to make sure.......
808Gt
115
Hawaii
Jan 2, 2006
  • Jan 2, 2006
WTF!!!!
I just changed the ignition lock and it still does the same!! its still on the on position, and when I put the new cylinder on it does the same ass before, I cant turn it off or on.....
I just look at the inside part of the ignition switch and i think its in the column that is broke..... F***k
Do anyone know if it is hard to fix the colum part were the ignition goes??
808Gt
115
Hawaii
Jan 2, 2006
  • Jan 2, 2006
K, i found out what was the problem..... After about 2hrs or so trying to figure out what was wrong, I found out that it was the part were the ignition switch connects to and were you install the ignition ksy lock cylinder to broke... I think the mechanisim in the back broke......
Now i want to know if there is anyway to take that part off, had a hard time trying to take it off to examine it, and also can i be able to replace it my self.....???
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
  • brandyn200
  • Jun 20, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
