Help!!!
  • Thread starter Thread starter NathanT
  • Start date Start date Jul 4, 2007
N
NathanT
  • Jul 4, 2007
Ok so ive gone through 5 starters now in a month... for some reason the case keeps breaking around where the bolts connect to the tranny. The tranny is a T5... any ideas on what could be causing this? thanks in advance =)
88stang_dreams
9
  • Jul 4, 2007
Do you have to bolts to tight or to loose? does it make any sounds when you turn the car over?
N
NathanT
  • Jul 6, 2007
Tight or loose the housing will break, and it just will not turn over. I went and got a high torque starter from a performance shop and it starts and did not break... but now all my cylinders are not firing properly... probably a different related issue but im going to check all the grounds tonight.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
