  • SN95 4.6L Mustang Tech
help
  • Thread starter Thread starter wicked02
  • Start date Start date Jan 29, 2011
W
wicked02
17
  • Jan 29, 2011
i need help bad. i have a 02 gt everything was running good. Got up one morning and it surges from 45 mph to 55 mph. replaced the air filter and fuel filter and check for vac leaks. don't know what else to do
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jan 30, 2011
  • Jan 30, 2011
When you mean surge in rpm's or mph's? Miles per hour could mean your throttle is sticking.
W
wicked02
17
  • Jan 31, 2011
like it's skipping, but not it's not bringing up the light or not giving the code
03_TrueBlue_GT
810
41
29
Houston, Tx
Jan 31, 2011
  • Jan 31, 2011
Well you can take your air filter off and check to see how dirty it is and if it is nasty go ahead and replace it. Then go and check your throttle body and check for carbon deposites on the throttle if there is a large build up of carbon on it go ahead and clean it with some throttle body cleaner spray. Also while your at it check to see if your fuel cable linkage has slack in it for any freeplay.
You could also check your IAC for any irregularities... Thats about all I can think of, also what grade of fuel are you using and is it fresh or old gas?
trinity_gt
3,125
81
99
Canada
Jan 31, 2011
  • Jan 31, 2011
FWIW, I advise against cleaning the TB in any way. There are coatings present intended to help the throttle plate seal so the IAC can do its job properly. Just leave it be...it's not the source of the problem.
You say the MIL isn't coming on but it sounds like you've got a misfire. Did you actually scan the car for codes with a scan tool?
What are the mods on the car?
Was the car re-fueled before this started? Any chance you've got water in the gas?
W
wicked02
17
  • Feb 3, 2011
i scan the car but no codes. i only run 93 octane and so far it just has a cold air intake for now. whatever it is it's getting worse just bought a set of coils and plugs going to change them.any other suggestions all are appreciated
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Feb 3, 2011
  • Feb 3, 2011
No need for 93 octane unless you have a power adder or higher compression than factory. Your car will run best on regular. (I doubt this will fix your problem but it will save you some money.)
W
wicked02
17
  • Feb 4, 2011
i just replaced all the coils and still does it. i am pulling my hair out
midnightdriver
443
Northern California
Feb 4, 2011
  • Feb 4, 2011
Skipping or slipping? If you have an auto I suggest taking a look at if you have low trans fluid and what color the trans fluid is. Sounds like slipping clutch packs if the speed surges like that or TC locking/unlocking.
mrvax
Feb 5, 2011
#10
  • Feb 5, 2011
  • #10
It may be time to take the car in. From your description, it could be a bad MAF to a bad fuel pump. Find a good shop to run some tests so you don't end up pissing away good money replacing everything.
W
wicked02
17
#11
  • Feb 5, 2011
  • #11
no,it's a manual trans. i am going to try some stuff before i take it in to dealer. i am just furious that i can;t figure it out
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
