How do I get the feul pump to run?
  • Thread starter Thread starter larrym1961
  • Start date Start date Mar 6, 2011
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Mar 6, 2011
  • Mar 6, 2011
I am doing a feul pump swap and new sending unit. I have 5 to 8 gal of feul left in tank and would like to pump out about 5 more gal to make dropping the tank a little easier.
I have tried jumping the feul pump test to connecter to a ground and I can not get the feul pump to run. It will only run a few seconds with the cycle of the key like it normaly does. To get it to run do I have to have key on or off? And the ground, does it jump to the computer test port ground or just a chassis ground?
I've read jrichker's post on tricking the feul pump to run but, I must not be doing the right majic because it is not working!
Any one know how to do this?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 6, 2011
  • Mar 6, 2011
Spell my name correctly and I will tell you the secret....
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Mar 6, 2011
  • Mar 6, 2011
I'll even put Mr. jrichker in here! what is your secret? I just don't seem to be doing it right.
and your posts are very helpfull! I try to take notes on all the stuff you have for everyone. Good job!
And I did correct the spelling to!
Thanks,
Larry
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Mar 6, 2011
  • Mar 6, 2011
Thanks,
Larry
I went back and jumped feul pump test port to Computer ground and then turned ignition key to run (just like you would to run codes) and the feul pump ran, and now gas tank is empty! Majic! Thanks again to one of jrichker's earlier posts for info on how to run pump. He is Stangnets favorite tool!
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
